Old 08-20-2013, 11:48 AM   #1
biohazardbill
Measurement request
I had new core support mounting hardware but apparently I lost them somewhere. Anyway I am trying to find motor/hood clearance. That being said I need to mock up the core support. Can someone grab me a measurement between the core sopport and the body mounts?
biohazardbill is offline   Reply With Quote
Old 08-20-2013, 12:26 PM   #2
1963c-10
1963c-10's Avatar
Re: Measurement request
I think this thread will help you out....
http://67-72chevytrucks.com/vboard/s...d.php?t=325736
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-20-2013, 12:54 PM   #3
biohazardbill
This has great frame info but doing a quick lookover did not see a dimension for the core support to body mount dimension. Basically need the dimension of the crushed core support body bushing.
Old 08-20-2013, 02:33 PM   #4
joedoh
joedoh's Avatar
I didnt have a tape measure but looks to be roughly 3/8"
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 08-20-2013, 02:46 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
new mounts will be a tiny bit larger just FYI.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-20-2013, 02:49 PM   #6
1963c-10
1963c-10's Avatar
I have a new mount kit at home and can measure the thickness once home. I misunderstood what you were looking for....I thought you wanted frame measurements from the core to the cab.
Old 08-20-2013, 02:55 PM   #7
joedoh
joedoh's Avatar
are you sure? the bolt holding these isnt loose, its still super tight. If the mount would have deteriorated or shrunk I would expect the bolt or the core to be loose
just asking a question, I would expect an uninstalled mount to measure larger, absolutely. If thats what you are saying, I misunderstood.
