08-20-2013, 12:27 PM | #1 |
Question about my 1971chevy truck k20
I bought my 1968 chevy truck k20 and it came with a 71 k20 also I got the vin plate and the title also. My question is if the vin tag is from a different truck it has no glove box so I can't look up the spid card the truck has been painted once so my question if the vin plate do people remove it to paint a truck? The cab appears to be a k20 cab has cab lights with the humps for the cab lights in the roof. The frame is all 3 /4 ton it has v8 motor mounts in it also the truck was also a standard at one point because there is a hole in the cab where the couch linkage was I also have a manual steering Column that came with it I have all the parts for it here's the truck and vin is ke24IT601076
Posted via Mobile Device Posted via Mobile Device
1968 Chevy K20 Long bed dump truck 1978 Chevy Custom deluxe long bed 1986 Chevy Custom deluxe short bed 1987 Chevy Custom deluxe short bed 1987 Chevy Silverado short bed 1990 Chevy Silverado K5 Blazer All four wheel drive! All non mutt trucks! Last edited by Big bad Green; 08-20-2013 at 12:36 PM. |
08-20-2013, 12:28 PM | #2 |
Re: Question about my 1971chevy truck k20
1968 Chevy K20 Long bed dump truck 1978 Chevy Custom deluxe long bed 1986 Chevy Custom deluxe short bed 1987 Chevy Custom deluxe short bed 1987 Chevy Silverado short bed 1990 Chevy Silverado K5 Blazer All four wheel drive! All non mutt trucks! |
08-20-2013, 12:32 PM | #3 |
There's red Peaking under the green
08-20-2013, 12:35 PM | #4 |
Just curious does the VIN (number) on the VIN plate match the number on the driver side frame rail? Do not remove the VIN plate to paint. Use a chemical stripper in that area the mask the VIN plate before painting.
08-20-2013, 12:51 PM | #5 |
There's a vin plate on the frame?
08-20-2013, 01:19 PM | #6 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-20-2013, 01:37 PM | #7 | |
08-20-2013, 02:10 PM | #8 |
Are the numbers spoest to match some numbers on the vin plate?
08-20-2013, 02:19 PM | #9 |
Yes its a partial, i don't remember how many digits it is
08-20-2013, 02:37 PM | #10 |
Can i get a photo on Were it Is at?
08-20-2013, 02:40 PM | #11 |
I'm at work, but I will take a pic tonight..Hopefully some one can post a pic before me.
08-20-2013, 02:53 PM | #12 |
Always on the hunt...
08-20-2013, 03:37 PM | #13 |
It on top of the frame rail on the drivers side.
08-20-2013, 03:41 PM | #14 | |
If you have the title, it shouldn't be a problem registering it regardless of what the frame rail is or anything else. It's all about the cab, the VIN plate and the title. You can put 1972 fenders, hood and grill on it and turn it into a 2wd shortbed and still register it as a K20 if that is what the VIN plate and title read. |
08-20-2013, 03:45 PM | #15 |
KE241T601076 = 1971, 3/4T, 4X4, (K20), gas engine, pick up (cab and bed) built in Tarrytown, Serial # 601076
You say you have a 1968 as well? Title on it too??? |
08-20-2013, 04:19 PM | #16 |
I just want to know uf Its had a cab Swap are the numbers on the frame on a tag?
08-20-2013, 04:24 PM | #17 |
I just want to figure out what I got
08-20-2013, 04:27 PM | #18 |
08-20-2013, 04:47 PM | #19 |
The numbers in the frame are stamped in the frame itself. You may have crud or rust to remove. I thought on one of mine they were actually stamped on the front frame horn too I believe
Posted via Mobile Device |
08-20-2013, 09:25 PM | #20 |
Any pics?
08-21-2013, 10:32 AM | #21 |
Here's some pics of my vin on my frame (as promised)
08-21-2013, 11:37 AM | #22 |
Thanks dale
08-21-2013, 11:38 AM | #23 |
08-21-2013, 11:48 AM | #24 |
The fender is 69-72 and the grill is 71-72..you can always send me the grill if you don't want it..
08-21-2013, 12:11 PM | #25 |
