Old 08-20-2013, 01:39 PM   #1
sunk99
sunk99's Avatar
400 turbo column shift linkage
Come off my 69 burb $60
Scott
sunk99 is offline   Reply With Quote
Old 08-20-2013, 09:01 PM   #2
mr_earnhardt1
Re: 400 turbo column shift linkage
Any pics?? Thanks
mr_earnhardt1 is offline   Reply With Quote
Old 08-20-2013, 10:29 PM   #3
sunk99
sunk99's Avatar
Couldn't add pics but I can text or email them.
Scott
Old 08-20-2013, 11:42 PM   #4
Classic Bowties
Always on the hunt...
Just an FYI, for the V-8 there were two separate TH/400 cloumn shift linkage setups. One is the standard small block with Th/350 & 400 setup with the second setup being for the big block with Th/400. Mel
Classic Bowties is offline   Reply With Quote
Old 08-21-2013, 12:05 AM   #5
jjzepplin
jjzepplin's Avatar
I might be wrong but those look to be different due to the different frame rail size between 1/2 ton and 3/4 ton. I am often wrong but the lower one looks like it would not fit in a 1/2 ton frame rail. Both of my 1/2 tons have the upper style and both were factory small blocks. HMMM as I scratch my head.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-21-2013, 05:10 AM   #6
sunk99
sunk99's Avatar
The one I have for sale is the small block style like at the bottom of the picture.
Scott
Old 08-21-2013, 06:56 AM   #7
teeitup
Just like to part out trucks!!
teeitup's Avatar
Both setups Mel posted are for 2wd's doesn't matter 1/2 or 3/4, the top set is the most common one for a turbo 400, lower set is the for th350. I personally have never seen the upper set on a th350 from factory
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 08-28-2013, 07:18 AM   #8
sunk99
sunk99's Avatar
Bump
Scott
Old 08-28-2013, 08:03 AM   #9
jjzepplin
jjzepplin's Avatar
That makes sense. I only own 4wd's. You are right and I am wrong.
Old 11-19-2013, 06:38 PM   #10
sunk99
sunk99's Avatar
Bump
Scott
Old 11-20-2013, 08:28 PM   #11
HotRod C/10
HotRod C/10's Avatar
Is that because TH400 equipped trucks were all Big Block from the factory?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 11-20-2013, 10:17 PM   #12
70STOVEBOLT
70STOVEBOLT's Avatar
All TH400 equipped trucks were not necessarily big block trucks. But all automatic equipped big block trucks used TH400 trans AFAIK.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 11-20-2013, 10:19 PM   #13
70STOVEBOLT
The question I have is, can I use the TH350 style linkage with a big block? If not, what will be the hang up?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 11-21-2013, 10:30 PM   #14
lha1992
lha1992's Avatar
Can I ask I have heard that the shift linkages on the 67-72 trucks will work on a 60-66 truck but I'm not sure.
I'm going from a powerglide in my 65 c10 to a th350 an wondering if this would work?
lha1992 is offline   Reply With Quote
