Old 08-20-2013, 02:02 PM   #1
Straight six
Straight six's Avatar
Edelbrock issue
Well I finally got the timing set enough to start up the engine. The issue now is when I start her up she idles at like 100 to 150 rpm then gradually gets up to idle speed. I have to give it heavy gas to keep from shutting off until it reaches idle. I thought when I start it up it idles high then tap gas pedal and goes down to idle speed. I must be doing something wrong
Straight six is offline   Reply With Quote
Old 08-20-2013, 02:13 PM   #2
Sodell
Sodell's Avatar
Re: Edelbrock issue
Is the choke hooked up?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 08-20-2013, 04:22 PM   #3
Straight six
Re: Edelbrock issue
Yea it's working. I'm not sure what it could be thought it was fuel psi but its fine. I just tried again starting it same thing starts at like 150 rmp sluggish like it wants to die takes like 15 to 25 seconds to get to idle
