Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-20-2013, 04:27 PM   #1
BIG DADDYS 84
spring side to side swap
ok just thinkin here,need more clearance on wheel back spacing,84 step
has anyone swapped springs side to side? moving hangers from outside frame to inside frame swapping sides and then moving perches inward. yes I~m sure bottom of frame rail will have to be notched,any ideas? wanting to set it down over big meats,without changing frame rails.thanks
BIG DADDYS 84 is offline   Reply With Quote
Old 08-20-2013, 04:37 PM   #2
tinydb84
tinydb84's Avatar
Re: spring side to side swap
I had thought about doing that once. I have heard of people doing it on here but have yet to actually see it. Most people were discouraging it due to poor handling (bodyroll).
David
Instagram: myfabguy
Old 08-22-2013, 05:28 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
I did this on a 55 chevy 2 door a long time ago . It worked fine
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-26-2013, 06:33 AM   #4
Hertzdaddy
Other option is mounting the leafs under the frame rails like s-10's. Would need to fab some mounts. I'd use sliders out back. May need to de-arch springs depending on desired ride height.
Hertzdaddy is offline   Reply With Quote
