Drop Shocks
Any body got a rferance # for a drop shock I dropped my truck 4" now I need some shorter shocks for the rear.I used springs for the drop and just need some in expensive shocks.Sure would like to go into ADvance Auto or ?? and give a part # .Not to concerned on brand THANKS
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: Drop Shocks
Nobody has found an alternative shock to use,How do I measure to find the correct travel I need.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Drop Shocks
I normally use KYB shocks from Early Classic Enterprises.
Re: Drop Shocks
Thats what alot of people do ,just figured I could find something else that would work.
Re: Drop Shocks
All right thanks for that info
Re: Drop Shocks
I have over a 4" drop on the rear of mine and i used stock front shocks.
Re: Drop Shocks
I made some top mounts and got my shock to sit more straight,put my original shocks back on.Will get some shorter shocks this winter(maybe)
Re: Drop Shocks
Trust me the stock front shocks work great on the rear. A lot of people on this board use them as a good cheap smaller shock.
Re: Drop Shocks
OK I took it out today and ran a little over a hundred miles ,they did bottom out on the bad bumps.You wouldn't happen to have a part # would you THANKS
Re: Drop Shocks
when you use the front shock for the rear. do you still have to use shock extenders??
Re: Drop Shocks
If u lowered the rear like I did somewher around 3 1/2" to 4" then I would recomend to relocate the shock top or bottom.I did and it drives like a differant truck now.My stock shock Monroe gas matic #56001 19.5"extened and 12." collopased will bottom out on a agressive bump/dip etc.. I looked on line (Adv.Auto)and found some Monroe #59041 that are a little shorter 14.6" extended and 10.1" collapsed
#13 |
Re: Drop Shocks
Just a note that I havent seen posted. I used a spring block combinatiin on my rear, and front shocks are too short with relocator brackets to work...
72 C-10 long bed 350 3OF 07 classic Z-71 xcab L-33 |
