Old 08-21-2013, 12:31 AM   #1
wwillmon
Possible LS swap?
So right now i have my 73 c10 down to the frame and can really go either direction with the motor and tranny. Right now i have a 350 sbc that i was planning on rebuilding (aluminum heads, cam, etc.), so i dont neccessarily need an ls but i would love to have one. After reading around though it seems like the ls swaps are the way to go as far as reliability and mps etc.
My problem is im not sure with which ls motor i would want to go with. I would want to be in the ballpark of about 450-500 hp, with room to increase so im guessing i would want one with an aluminum block? My other thing is i like the looks of the old sbc and bbc motors with hardly any wires under the hood, and with the ls i know im going to have plenty of wires t run, so is it possible to clean these up and make them look show quality in our trucks (paint, wiring, etc.) This truck will just be to cruise around in and put in shows, but i want to do it right the first time and not regret my choices, so any help would be appreciated.
wwillmon is offline   Reply With Quote
Old 08-21-2013, 12:45 AM   #2
Special-Ed
Special-Ed's Avatar
Re: Possible LS swap?
lsx is where its at.... reliable, lots of power, and good on gas
there are 2 versions of the ls3 something like 420hp and the 480 hp...
with a supercharger it goes upto 620hp or something like that
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 08-21-2013, 12:49 AM   #3
wwillmon
Ill definitely check the ls3 out. Been trying to read up and figure everything out but theres so many different models, and ive never messed with ls motors so its taking me a bit to figure it all out haha.
Old 08-21-2013, 09:25 AM   #4
Jon01
Jon01's Avatar
Any LS motor can make 450hp fairly easy.
I'd just start with a run of the mill LQ4, 243/799 heads, car intake, cam and headers and you'll be knocking on 500.
Do some reading over on LS1tech if you're new to them.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 08-21-2013, 12:55 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You can always run an ls motor with o/d trans carb'ed, and keep the ecm in the cab. You'll have more wires than before but much less than the full efi/dbw conversions.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-30-2013, 02:19 AM   #6
wwillmon
The more and more i think about it, the more i want to do it and am convinced im going to. Would it be better just to do something like a LQ4, or should i just start with something like a LS1, or save the money and go with something like a LS3 or something. Still trying to figure out which way i want to go.
Old 08-30-2013, 08:01 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
like was said before, an LQ4 with the 243 heads and a nice cam, performance tune and headers will get you right around 450-500HP. Then later if you need more power ( not sure why but you never know) you can throw a bottle, a supercharger or a couple turbo's.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-30-2013, 09:29 AM   #8
Jon01
Jon01's Avatar
What Clyde said.
LQ4's are cheap, plentiful and can make plenty of power n/a with a head swap or if you want boost leave the stock large chamber heads on it and crank it up.
Old 08-30-2013, 10:50 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by Jon01 View Post
What Clyde said.
We just put some worked 317's on an ls1 with a 76mm snail....it sounds like an angry badger in heat, and goes like one too. Boost plus anything works for me
