Old 08-21-2013, 01:08 AM   #1
Kaotik Kustumz
Kaotik Kustumz's Avatar
Question Dropped '86 LWB....(QUESTION)
Hey guys i was wondering if somebody could tell me just how much it will lower my truck if I pull coil springs in the front and chop off 1 full coil and put on some 2 1/2" drop spindles, and then run a flip kit in the rear....
I was told it would be bout a 4" front drop and a 6" rear drop....
2 1/2" drop spindles and 1 full coil cut off in front = 4"
Rear flip kit (NO C-NOTCH and NO BUMP STOPS) = 6"
KAOTIK Kustumz
1984 Chevy 1 Ton Crew Cab Dually "Western Hauler"454, th400, (6.0, 4l80e Swap Coming Soon)(5/7 Drop Coming Soon) (ON HOLD FOR NOW)
1986 Chevy 1/2 Ton LWB Silverado350, 700r4, (5.3, 4l60e Swap Coming Soon)(4/6 Drop)
Kaotik Kustumz is offline   Reply With Quote
Old 08-21-2013, 02:31 AM   #2
bigwheel15
bigwheel15's Avatar
Re: Dropped '86 LWB....(QUESTION)
A full coil cut is good for about 2" of drop, so combined with the drop spindles you'd be at approximately 4 1/2" up front. And depending on how many leaves are in your rear leaf packs you would see between 5"-6".
bigwheel15 is offline   Reply With Quote
Old 08-21-2013, 07:50 PM   #3
Kaotik Kustumz
Talking Re: Dropped '86 LWB....(QUESTION)
Sweet thanx bro
KAOTIK Kustumz
Old 08-21-2013, 11:55 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Remove the bump stop bracket on the rear of frame.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
