Rear fender install
Hey guys I tried to do a search here but it isnt working for whatever reason. I am getting ready to install a 4 link in the rear of my 1952 chevy truck and need more tire clearence in the rear. I was going to cut the bedsides out and install trailer fenders to give me wheeltubs. I am a complete novice when it comes to sheetmetal and bodywork so I was wondering how I should attach them to the bedsides? I hear people say welding tubs to quarter panels will distort the quarter panel whenever I hit the gas due to the flexing involved. Should I just use seam sealer to attach to the bedside? Any help, photos would be GREATLY appreciated. Thank you all
Re: Rear fender install
you could cut an 1.5" wide arch out of sheet metal. Weld it to the underside of the tub, then bolt or weld it to the bed side, that would hide the attachment to the bedside.
then make a lip an 1" or so to attach to the bed floor, close up the inside of the tub with a 1/2 round sheet. I also saw a a guy use a right fender cut down on the inside of the left for the left tub. and viseversa, if you got a set of extra rear fenders laying around |
I've seen a few that used the inner wheel tubs from the fleetside pickups that bolt in and look proper when you are done. I've seen at least one set that a guy narrowed down as mini tubs that looked like they came in the truck to begin with.
The trailer fenders could be made to work easily enough and they are fairly inexpensive if you hunt around a bit. Locally the farm and ranch store has several different ones that would work.
A320 Pilot/USAF Retired
There are several ways to mount them, check out my thread at post #246 to see one way of doing it. Good Luck and show us some pics!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I did the same as Ogre.^
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where ![]() |
I really like the way yours turned out. Now you got me looking for old suburban fenders to use. I might look at the later C/10 wheel wells as well. Either way I Have enough stuff to work on this weekend with it anyways. i will try and find a few picks of the truck to pop up on here. I plan on starting a build thread for it but im kinda embarrassed after seeing some of the stuff on the forum. I have taken many 180's with the truck and went backwards almost as much as Ive gone forewards.
