3" or 4" drop in rear with 2" front lowering coils
I've got a 70' C-10 2wd Stepside that I'm converting to disc brakes and using 2" lowering coils on the front. Have you used 3" or 4" in the rear? Will be replacing entire front suspension but probably not rear other than coils so it's likely to be original.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 3" or 4" drop in rear with 2" front lowering coils
I would use a 4" drop spring to level out the rear of the truck.
Thanks, I was thinking 4". Just wanted some other opinions since I'm a novice in this area.
Grandpa in the rustmobile...
Id do 4 too. Cant go too low
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
