The Crazy Machanic
nv3500 bolted to a sb400 ?
has any one else done this im currently doing it and seeing if any one else can point me in right direction as far as flywheel and clutches.
my truck is an 86c10 auto that im converting to hydraulic manual. any help would be great What i know so far because the 400 need an externally balanced flywheel i cant use my flywheel from the 350. the 400 flywheel is 11 in disc set up and the factory one is a 10 !/2 ? i think. thus ill need to find an 11 in clutch system that will fit the input shaft of the nv3500. also i either need to find or make a hydrolic clutch pedal assembly.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one
| Bookmarks |
