Old 08-21-2013, 07:00 PM   #1
NC_John
NC_John's Avatar
New Door Weatherstrip - Have to SLAM doors
I put on a pair of new (Made in the USA) door weatherstrips on the weekend (purchased from a forum supporting vendor). I'm talking about the ones that mount on the cab door openings to seal the perimeter of the door.... Not anything on the door itself.
I have to give the doors holy hell now to close them. How long is THIS going to last? Its ridiculous how hard I have to slam the doors to close them. I don't believe they are out of adjustment, they closed pretty good with the old weatherstrip.
BTW- the set I removed was glued on. I'd like the strangle the m.f'r that installed them. It was insane how much glue he used and it was a PITA to get off. Literally hours and hours of scraping and cleaning.. The set I just installed are the better clip-on type.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-21-2013, 07:09 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: New Door Weatherstrip - Have to SLAM doors
They all do it. They will break in over time.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-21-2013, 08:47 PM   #3
cdowns
cdowns's Avatar
the guy in the factory assembling the trucks 40years ago was just doin his job when he glued each and every one in place
can you imagine doin a job like that 8hours a day forever
sometimes carefully heating them with a heat gun can speed the breakin process
Old 08-21-2013, 09:43 PM   #4
slow-1
slow-1's Avatar
Also, spray some of your favorite lube (Silikroil is my fave) on door hinges and the star wheel on the latch...it will amaze you how much less you have to slam it.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 08-21-2013, 09:43 PM   #5
NC_John
NC_John's Avatar
Judging by the mess of glue that I had to clean off, that was NOT factory!
1970 C-10 LWB "Blu"
Old 08-21-2013, 09:45 PM   #6
NC_John
NC_John's Avatar
I'll give that a try, thanks..
1970 C-10 LWB "Blu"
Old 08-21-2013, 09:53 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
I agree. They all do this and it takes time. Is there enough of a gap at the meeting point (under the sill plate) to let air escape? If the seal is butted together and the meeting point, you may need to trim it a little.
TBONE1964 is offline   Reply With Quote
Old 08-21-2013, 10:20 PM   #8
NC_John
NC_John's Avatar
Ah nuts- I put the joint up by the dash/door jam.... I forgot that the door sill would hide it. Guess I'm pulling and re-planting it.
Gap is not an issue though- it does it with the opposite door open.
Thanks...
1970 C-10 LWB "Blu"
Old 08-21-2013, 10:46 PM   #9
In The Ten Ring
Just an idea, if you had vent window thingies (it attaches to the top of your door to allow you to keep the windows rolled down a bit just to let the air move yet not get rained on) you could roll the windows down just a bit and that would let air escape as you shut the door.
I am printing out this string as I will soon face this same issue.
In The Ten Ring is offline   Reply With Quote
Old 08-22-2013, 03:00 AM   #10
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Same problem on mine when I first put on new seals. If you've got the foot vent thingies, keep 'em open. That's what I did until the seals broke in.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 08-22-2013, 05:28 AM   #11
Steve Hafner
Steve Hafner's Avatar
THREE years later . . . and we're STILL slamming the doors !!!
Steve Hafner is offline   Reply With Quote
Old 08-22-2013, 07:23 AM   #12
NC_John
NC_John's Avatar
Yeah but I still have to slam it even when the other door is wide open..... I can see that perhaps being an issue later but not yet. Especially with the holes in the cab corners!
On your truck or is this a rerun on the forum? (My bad for not doing a search)
1970 C-10 LWB "Blu"
Old 08-22-2013, 09:15 AM   #13
volksworld
leaving the air gap at the bottom is to let air escape from the seal itself as it compresses,not from the cab....know how you feel...went through 3 brands of seals before I found ones that worked....softseal were wound so tight in the package that when you straightened them out they looked like a piecrust...steele rubbers were too thick and the doors wouldn't close....the final set were cheap ones from year one...they work fine, but I spent so much time removing that glue and painting the door jambs I haven't been able to bring myself to gluing them in yet and was considering push-on ones instead but from what I've read here the push on ones are harder to close...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 08-22-2013, 09:36 AM   #14
NC_John
NC_John's Avatar
that makes more sense as far as the gap goes. when I redo mine to put the gap on the bottom, I will give them a little more breathing room.
thanks.
1970 C-10 LWB "Blu"
Old 08-22-2013, 09:44 AM   #15
68gmsee
Active Member
68gmsee's Avatar
I used the push on type from GMCPaul some years back and had to do the same. It did finally settle in after a few Texas summers.
Right after I installed them, I adjusted the striker plate on the cab out slightly to make it easier to shut and still keep a tight fit. Also found out that if I closed the door to within 6 inches of closing before I shut it forcefully, it was easier to close.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-22-2013, 10:08 AM   #16
71sierragrande
Petroleum User
71sierragrande's Avatar
Count your blessings. I wish i had to slam my doors. A 2 mph breeze could latch em
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 08-22-2013, 03:14 PM   #17
gmillion1
gmillion1's Avatar
a few things i did to help after installing my new seals:
-i noticed the point where the a-pillar met the roofline, the seals were really thick, so i cut out a small bit in that spot.
-cut some slits on the interior side of the seals to let air out when shutting the door
-used Meguiars interior protectant (not armor all, i hate armor all) ,
to lubricate the seals.
my doors went from requiring a slam, to closing with a gentle push.
gmillion1 is offline   Reply With Quote
Old 08-22-2013, 09:17 PM   #18
Steve Hafner
They were installed three years ago and I still have to slam the doors WITH or without the windows being rolled down.
Old 08-23-2013, 06:49 AM   #19
NC_John
NC_John's Avatar
ahhhhh.... I'm going to let them break in a bit and try some of the ideas shared here but seriously- if I am still having to slam them the way I am now, after they have had a chance to break in, I am getting different seals. This is embarrassing how hard they have to be closed. The truck looks like a POS to everyone else (non-enthusiasts!) right now and that makes it sounds like one too! I'm going to lose my mirrors if I have to keep doing what I'm doing.
At least these are clip on so I don't have to go through that glue removal disaster again!
1970 C-10 LWB "Blu"
Old 08-23-2013, 12:13 PM   #20
NC_John
NC_John's Avatar
Ha! I knew I put the seam in the front section of the door jamb (up by the dash) for a reason. Though I didn't know it at the time, the factory wants it installed this way too. They also say to cut a 45 degree "V" at the joint to let air escape.
I am flipping through the service manual looking for some guidance on all the door/side window seals and came across it....
1970 C-10 LWB "Blu"
Old 08-23-2013, 12:16 PM   #21
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by NC_John View Post
ahhhhh.... I'm going to let them break in a bit and try some of the ideas shared here but seriously- if I am still having to slam them the way I am now, after they have had a chance to break in, I am getting different seals..............At least these are clip on so I don't have to go through that glue removal disaster again!
As I mentioned on my post above, try moving the striker plates out slightly to see if that helps -at least until they break in.
First pic shows the push on type seals from GMCPauls and the second the plate you can adjust.
06 Trailblazer
Old 08-23-2013, 06:34 PM   #22
NC_John
NC_John's Avatar
I actually adjusted the door IN this afternoon- when closed the door still stuck out (even with the old seals) nearly half an inch. I cut an air gap in the weatherstrip. Seems to maybe be a bit better. I spent a lot of time with an old school bodyman when I was a kid so I am pretty good with adjusting doors and body panels.
The seals I got that are giving me all this grief are the ones from GMCPauls.
thanks.
1970 C-10 LWB "Blu"
