Old 08-22-2013, 01:17 AM   #1
jd21476
jd21476's Avatar
Headlight switch removal?
Which way does the knob on the headlight switch turn to unscrew it? I'm trying to remove the switch to replace it but the knob won't unscrew.
jd21476 is offline   Reply With Quote
Old 08-22-2013, 01:42 AM   #2
mongoose
mongoose's Avatar
Re: Headlight switch removal?
i just rip it off... there's like a clip that holds it on..
not sure if this is the right way but it works.. just push it back on.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 08-22-2013, 01:42 AM   #3
izzy_Britton
izzy_Britton's Avatar
NEITHER!
there is a button on the headlight switch assembly that is spring loaded (on the backside of the dash)
push that button, pull the knob til it stops, depress button again and give it a hardy yank, not so hard you bust the thing but enough that it comes free. then you will have the knob and the shaft in your hand. the assemble has a retaining screw behind the dash bezel holding the assembly to the metal dash.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
