Old 07-05-2003, 04:25 PM   #1
Ron
Ron's Avatar
Electrical Problems, oil pressure gage line
Subject vehicle is a 67 C-10. I have constant 12 volts to the right and left turn signals. Signals blink ok but when the turn signal lever is returned to nuetral position the bulb remains on. I have 12 volts at these wires even with the key off.
Also, I do not have the oil gage to engine block oil line and cannot find the correct combination of fittings to make a new one. Where can I get one? Thanks
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 07-05-2003, 05:52 PM   #2
McGillicutty
I got an oil line at the local parts store. They had both plastic and copper lines. The kit also had several different fittings with it.
McGillicutty is offline   Reply With Quote
Old 07-05-2003, 06:02 PM   #3
Dean23
68cst_ss490
Dean23's Avatar
seems to me u have a short in the wiring somewhere. make sure that oyur ground is good. I've seen grounds cause some weird faults.
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 07-06-2003, 01:09 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Something sounds funny, you saying the turn signal indicators stay on even after shutting the eng off?
Old 07-06-2003, 01:47 AM   #5
Ron
Ron's Avatar
Yes, if the signal is in the right position the light will blink until you put the lever in the nutural position, than it will stay on. (Left signal does the same thing). Spent most of the day trying to figure this one out.
'69 SWB
