Old 07-05-2003, 04:29 PM   #1
meathead95
computer illiterate
meathead95's Avatar
mechanics i have a ?
I have a 96 olds cutlass supreme and here lately when you are accelerating the air quits blowing and when you let off the gas it starts blowing again. any ideas?
Thanks in advance
Keith
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 07-05-2003, 04:48 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
do u mean the fan in the heater slows down and speeds up. if so the alternator is on ts way out, time for a new one
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 07-05-2003, 05:06 PM   #3
john
member #16
john's Avatar
Sounds like your vacuum supply is dropping under acceleration. See if you have a vacuum reservoir for your heater a/c controls. split hose etc.
john is offline   Reply With Quote
Old 07-05-2003, 05:28 PM   #4
cableguy0
some cars im not sure if that is one of them have like a cut off switch for when ur under wide open throttle it gives u the power by turning off the a/c compressor and as the other said check all you vaccum lines for a leak
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-05-2003, 05:54 PM   #5
Dean23
68cst_ss490
Dean23's Avatar
i need to read closer i thought it said shuts off when releasing throttle... i agree with a possible vac leak or maybe a poor connection somewhere and the weight transfer of accel pulls on wires and lossens the connect then on decel and cruise it comes back together
Dean
edmonton,canada
a winter wonderland
Old 07-05-2003, 07:56 PM   #6
Piston
Piston's Avatar
A common area: there is a vacuum resevior located either next to the brake booster or near the drivers side fender/core support area. It's very easy to pull the hose off of the vacuum canister and will cause the exact thing that your describing.
As mentioned before, check your vacuum supply, canister, one-way check valve operation and if everthing is in order you could have a problem in the control head (vacuum leak) or a vacuum pod.
Piston is offline   Reply With Quote
Old 07-05-2003, 08:34 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Piston's answer is going to be right on the money...
It's probably a vacuum problem. I bet, that it doesn't quit blowing, it just blows out the defroster instead of the vents, when it happens. Classic symptoms of a vacuum leak to the canister, or check valve failure.
Old 07-06-2003, 08:54 AM   #8
meathead95
computer illiterate
meathead95's Avatar
your right it doesnt quit blowing all together it just blows on the floor and the vents quit i will check it out tomorrow thanks fellas
72 2wd blazer
72 swb 4x4
