Old 08-22-2013, 12:30 PM   #1
sush1024
sush1024's Avatar
Battery not charging
I have a 67 c10 and a the other week my altinatior went bad so i replaced it and the truck ran fine for a bit and now the battery wont charge. I put a new voltage regulator in it today and the truck still wont charge. Any advice?
sush1024 is offline   Reply With Quote
Old 08-22-2013, 12:54 PM   #2
sKnNyPpY
sKnNyPpY's Avatar
Re: Battery not charging
Bring the alt and reg back and get an internally regulated one, the price should be about the same. Jump a couple of wires and many charging issues magically disappear. I changed the alt and reg and thought I was fine until I realized I was just running off a freshly charged battery. I chased wires for weeks and couldn't solve my problem until I switched. DO the conversion, you won't regret it.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
This is the basic idea. I jumped the wires differently via VetteVet's instructions
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 08-22-2013, 01:10 PM   #3
Bigdav160
Bigdav160's Avatar
How do you know the battery is not bad? Most alternator failures are caused by bad batteries.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-22-2013, 02:34 PM   #4
54blackhornet
54blackhornet's Avatar
You will find two little 4 amp fuses in harness that runs across top of core support, check them ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-22-2013, 05:08 PM   #5
sush1024
sush1024's Avatar
i checked the battery just a little bit ago it is no good thanks for the advice. and after i replace the battery i will get a internally regulated alternator, sounds like a really good idea thank you
