Old 08-22-2013, 01:59 PM   #1
1972Blaze
Question about 16.5 x 8.25 Steelies for 1972
I know these did not come with hub caps. Did they have small holes that may have had been for clips near the inside close to the lug nut holes? I just got a set and they have the holes. I am trying to decide whether or not to fill the holes based on what the original configuration would have been. Thanks.
1972 K5 Blazer Cheyenne
1966 L72 Corvette Convertible
2016 GMC Yukon Denali
1972Blaze is offline   Reply With Quote
Old 08-22-2013, 06:55 PM   #2
factorystock
factorystock's Avatar
Re: Question about 16.5 x 8.25 Steelies for 1972
Any photos? 1969 thru 1972 3/4 tons all came with bumps, to match the 12" diameter hubcaps. If your wheels originally had clips, they are correct for 1967 and 1968 3/4 tons, which used the smaller 8 3/4" cap.
factorystock is offline   Reply With Quote
Old 08-22-2013, 08:21 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
These steelies if correct for 69-72 will take hubcaps - see an example of mine in my K20 build thread below...not sure about the small holes. Can you post up a pic?
Old 08-23-2013, 07:57 PM   #4
1972Blaze
Here is a picture. I am sure from looking at original literature that in 1972 a Blazer came without hubcaps. but did they have holes for the clips to be riveted on?
Old 08-23-2013, 08:23 PM   #5
jocko
jocko's Avatar
always thought 16.5x8.25 were 8 lug 3/4 ton wheels...? That is the size on my 3/4 ton anyway
Anyway, I believe that there would be nubs - but no clips in 72. I'm not a Blazer guru, but that's my understanding. Are your 6 lug wheels stamped? Factory K5 blazer should have 15" 6 luggers, I believe.
Old 08-23-2013, 11:24 PM   #6
factorystock
The plot thickens! Ok, 6 lug. Yes, the 16.5" 6 lug wheel was optional on '72 Blazers. The same 16.5" wheel originally had clips on 1967 and 1968 1/2 tons, but 69 thru 72 16.5" wheels did not come with clips, due to the new hubcap design that did not fit.
Old 08-23-2013, 11:50 PM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I had a set of those wheels, they were kelsey hayes after market purchased from a tire store. They were note factory
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-24-2013, 12:27 AM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
16.5 x 8.25 6-lug were definitely an option on Blazers. I'd like to have a set for my 72 K5 to match those 8 luggers on my K20! Caps were available on Blazers for sure but whether they were standard I don't know. Sure no nubs on those wheels? A lot of the center is outside the field of view so I can't quite tell.
Old 08-24-2013, 05:40 PM   #9
factorystock
The exact same 16.5" wheel is shown on the cover of the '72 Blazer brochure. This wheel just has the holes, clips were never installed, because '72 hubcaps do not fit these rims.
Old 08-24-2013, 07:48 PM   #10
1972Blaze
Perfect! I've seen that pic before, but never thought that looking at it closely would reveal the holes. That is exactly what I was looking for. I really did not want to fill the holes and this makes my decision easier.
Thanks.
Old 08-24-2013, 10:26 PM   #11
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I found the 16.5 x 8.25, six hole wheels listed for 1/2 ton and Blazer 4x4's in my 1970 parts book, so they were available in '70 and '71 as well.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-24-2013, 11:14 PM   #12
MusicMan70
MusicMan70's Avatar
1972Blaze would you please post a photo of the whole wheel. Is the size stamped on the inside or outside? Thanks.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-25-2013, 12:02 AM   #13
jocko
jocko's Avatar
Thx factorystock! I learn something new every day.
Old 08-25-2013, 12:21 AM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Pics - some w clips - maybe others without any provision for caps:
Old 08-25-2013, 08:01 AM   #15
The wheels aren't the option. The option is for 10.00" tires,which were only available in heavier load ranges in 16.5. I had a '71 K/10 Custom with chrome hubcap option and 8.25 x 16.5s. I've had after market Kelsey Hayes 6 and 5-lug 16.5s with nubs. Not sure what the deal is but some came with hubcaps. The centers are the same and the rim is different,so the 1/2t caps are what is used.
Old 08-25-2013, 04:20 PM   #16
factorystock
If you look closely at the GMC brochure, the hubcaps have been drawn in, in other words, it is a doctored photo. There are later versions of the 16.5" wheel with bumps ( post '73), but early versions ( pre '73) of the 16.5" were originally designed with clips.
Old 08-25-2013, 09:39 PM   #17
1972Blaze
Okay, I have a couple more pictures. I looked closely at the wheels and they have a 1972 date on them. No nubs for hubcaps as you can see. I appreciate any info someone can give me about these wheels.
Old 08-26-2013, 07:16 AM   #18
factorystock pretty much summed it up in the prior post.
