Old 08-22-2013, 03:21 PM   #1
Phill
In-tank electric pump for behind the seat tank?
Has anyone done this? I'm thinking of getting out the TIG welder and making a stock behind the seat tank except a Walbro 255 and sump, but I thought I would check here for info?
I'm dropping a ramjet 350 in this winter, and feel like the intank pump will still be quieter even though its in the cab, then a external pump.
Any opinions are welcome, I want to keep the behind the seat tank for no other reaosn then I like it there, I like the filler cap on the side of the cab, and I like not having one on the bed/box.
-2010 Silverado daily driver, 5.3, 24's, HP tuners ect
-2006 Silverado 6.6 Duramax, 6" lift, 37's, efi live
-1988 S10 10 point cage, 383, linked,1-tons 42's
-1971 1/2 ton 4x4 SWB, Ramjet 350/SM465/NP205, 6" lift, 35" BFG's, 15x8 ralley's, and lots more to come....
-1957 GM 3800 (9433) Napco 4x4, She's rough and I love it!
Phill is offline   Reply With Quote
Old 08-22-2013, 05:06 PM   #2
SS Tim
SS Tim's Avatar
Re: In-tank electric pump for behind the seat tank?
At those kind of working pressures I would not want a flex line inside the cab with pressurized fuel. Plus a formed tank (by most people) is not going to be as neat as the stock stamped tank. If you feel you must use an intank pump go through the stock sender hole.
SS Tim is offline   Reply With Quote
Old 08-22-2013, 05:30 PM   #3
67 chevelle
67 chevelle's Avatar
sounds like a plan , great engine choice , the only drawback I can think of would be noise , might be loud , im sure someone has done it , you might ask on ls1tech also , as most are injected , good luck and do a build thread when you get started
67 chevelle is offline   Reply With Quote
Old 08-22-2013, 05:33 PM   #4
68 short step
i have done this, you'll find that a fuel pump doesn't fit through the stock sending unit hole, its too wide... but with a little creativity, welder, and some fittings you can make it happen...
68 short step is offline   Reply With Quote
Old 08-22-2013, 05:33 PM   #5
FLDBRED
That's a great looking truck, any other pictures?
FLDBRED is offline   Reply With Quote
Old 08-22-2013, 05:35 PM   #6
Madmartigan
Custom Classic Trucks Magazine did a EFI conversion and kept the original tank behind the seat. I found the article on their website. EFI_Tank
Madmartigan is offline   Reply With Quote
Old 08-22-2013, 05:45 PM   #7
Phill
[QUOTE=68 short step;6233861]i have done this, you'll find that a fuel pump doesn't fit through the stock sending unit hole, its too wide... but with a little creativity, welder, and some fittings you can make it happen...
QUOTE]
This is what I'm talking about! What did you use to seal your tank flange? I'm thinking of using the GPA series pump and mount from tanksinc and putting it beside the original pickup, then keeping the original for the fuel level sender.
How loud was this in the cab when said and done? The fuel and seat should muffle it better then a frame mounted external I'm thinking.
I will be sure to start a build thread, this winter this truck should get 100% new drive train, I'm taking it to Alaska and want it to run like a top.
Old 08-22-2013, 06:10 PM   #8
68 short step
yes, look under my sig at project big red
[quote=Phill;6233886]
QUOTE]
This is what I'm talking about! What did you use to seal your tank flange? I'm thinking of using the GPA series pump and mount from tanksinc and putting it beside the original pickup, then keeping the original for the fuel level sender. i moddfed the stock sending unit , then replaced the stok sending unit with a autometer one... ill see i can find some more pics
How loud was this in the cab when said and done? The fuel and seat should muffle it better then a frame mounted external I'm thinking. not 100% sure yet, but it is quite muffled with the seat, sound deading material, and carpet installed. i also used the cork gasket material to seal the flange area
Old 08-22-2013, 06:14 PM   #9
68 short step
Old 08-23-2013, 08:10 AM   #10
Katrina/10
Katrina/10's Avatar
An 87-90 Chevrolet truck TBI pump fits in the tank with no mods.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 08-23-2013, 08:39 AM   #11
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
The TBI pump will not fulfill his fuel needs, the TBI pump will only generate 15-18psi or so, a MPFI system like the Ramjet he is installing needs 50-60psi to operate.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 08-23-2013, 03:39 PM   #12
MARKDTN
If a GM TBI pump fits then a TPI and an LT1 pump are the same size so they will fit too. '89 IROC for TPI and '96 Caprice for LT1
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-23-2013, 03:43 PM   #13
Katrina/10
Katrina/10's Avatar
Just saying a TBI pump fits, if a high pressure pump had the same dimensions, it would fit also.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 08-23-2013, 10:48 PM   #14
mtm_seven
Loading.....
mtm_seven's Avatar
I can confirm that an external pump with a stock tank will not work properly. I tried that caca for months before I broke down and got a boyd's tank with an internal pump. High pressure pumps do not "suck" much if at all. so when the pump is trying to pull fuel down to the frame, it starves.
The aeromotive pump that came with the Boyd's tank gets loud when fuel level is low. I can imagine that it would get pretty annoying in the cab.
Once I removed my stock tank, I left the cap to give the illusion that the tank wasn't moved. (if your intent is to keep that part looking stock)
Just another idea. Albeit an expensive one.
-M7
'69 SWB GMC 5.7 EFI
‘69 C/10 SWB patina survivor
‘71 K20 LWB GMC
'72 K5 1-ton gear 468BB
‘79 K20 LWB GMC
‘86 K30 GMC High Sierra C&C Single Cab
‘94 LWB GMC 2500 4x4
'96 SWB Single Cab 5.7
‘99 SWB Z71 Single Cab
'01 K2500 Yukon Safari 6.0
‘06 1500 LWB 4x4 5.3
‘06 2500HD Single Cab C&C Duramax 4x4
'08 2500HD x-cab duramax 4x4
'11 2500HD Single Cab Duramax 4x4
mtm_seven is offline   Reply With Quote
Old 08-23-2013, 11:00 PM   #15
67_C-30
I have a radical idea!
67_C-30's Avatar
My buddy has done several of these using TPI pumps. He was able to fit them through the stock hole.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-03-2014, 10:45 AM   #16
Phill
Ok, I'm about to put a walbro 255 on the tanksinc PA mount into the stock tank, is there any comments on how loud a intank pump is in the in-cab tank??
I will most likely dyno-mat the tank, but I'm worried it will drone in the cab a little now.... hopefully the headers, 3" pipes, and 40 series flowmasters on the ramjet drown it out :P
Old 02-03-2014, 07:50 PM   #17
imjeff
imjeff's Avatar
I still like the plan of soldering bungs in the bottom of the tank that are tee'd together to supply an external fuel pump, then using the original supply line as a return. Nice truck BTW!
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 02-04-2014, 12:44 AM   #18
Daaaanz67
Nice truck. If you can get this to work it will be awesome. Can I suggest you take a look at ls1nova build thread and check out the sump system he installed on the stock tank. Would help with fuel starvation if you could sink that pump in a sump. I try to keep my tank 1/4 full all the time with my ls conversion. My external walbro is mounted on driver side frame rail and can only hear it at initial start.
Daaaanz67 is offline   Reply With Quote
Old 02-04-2014, 03:58 AM   #19
Rod Run
Rod Run's Avatar
I would think the noise from the pump would drive me crazy. Lots of times you can still hear pumps when they are mounted at the back of a vehicle, when it is even outside the cabin.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-04-2014, 10:16 AM   #20
bMr
If you want to keep the stock tank then search for the Edelbrock Universal EFI Sump Fuel Kit.
"This Universal Sump Fuel Kit is designed to provide the necessary high fuel pressure required for EFI applications in vehicles equipped with low pressure carbureted fuel systems. It's a complete self-contained system that can be installed under the hood of any vehicle easily. The unique design of this system allows it to deliver a constant fuel pressure of 49 psi or 60 psi, which is necessary to operate an EFI system and will not require a fuel return line. This kit is intended to be used with the existing factory fuel tank and low pressure pump. The kit includes the fuel Sump tank with high pressure pump and regulator pre-installed, wiring harness, mounting bracket, hose, fittings and all of the necessary hardware for installation."
It is designed exactly for these types of situations...which means it isn't cheap.
However, the stock fuel tank doesn't need to be relocated or modified in any way and there is no chance of cornering causing fuel starvation at lower fuel levels (as may be the case with an unbaffled tank and a high pressure electric pump).
bMr is offline   Reply With Quote
Old 02-04-2014, 12:04 PM   #21
Phill
well I whipped this together last night. If its too loud I will dynomat the tank, if its still too loud I will do something else. My buddy has external pumps and they drive me crazy. Even with my ear to the tank in my blazer with the same walbro 255 pump its quieter.... so we will see.
I was anal with the measurements but I have the sump exactly 1/4" off the floor of the lowest part of the tank. I didn't baffle anything, but if its quiet and I run into fuel starvation problems I will build a baffled tank. I managed to not have to weld anything on the tank so I used my old one. I have a brand new one should I want to weld baffles in. Considering how low I got the pump, and how tall and narrow these tanks are.... I suspect baffles aren't to critical... for non-racing.
BMR, if I had of seen that from day one I may have went with it.
Old 02-04-2014, 12:04 PM   #22
Phill
more.
Old 02-04-2014, 03:35 PM   #23
svgould
Active Member
svgould's Avatar
Originally Posted by Phill View Post
more.
Where did you get the bulk head that has the 90 fittings and electrical connections? The zinc colored part? I have some idea's and need that exact part!
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 02-04-2014, 04:08 PM   #24
Phill
Tanksinc.com its their universal "GPA" mount.
Old 02-04-2014, 09:59 PM   #25
BigCountryx
BigCountryx's Avatar
Nice job Phil. I guess you used the GPA-4 and modified the Lines inside the tank.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
