Stock intakes question
This is probably a dumb question, but what is the value of boring out a stock intake? From an engineering standpoint, I mean. And can it even be done? For example, say for originality purposes, I want to keep my stock intake. But, as we all know, they flow like poop compared to all those aluminum ones from companies like Edelbrock or Trick flow. And, many of us want more power.
So, could a stock intake be "bored" out, through all the passages? I'm not talking about just simple port matching, though of course that would be part of the process. I'm talking about gutting out even more metal, all the way through the WHOLE intake. When you port match, all you do is match the port sizes. You don't do anything else to the rest of the runner for that hole. Is there some way to make the rest of the runner the same size as the port that you just matched to the head? All the way to the top. Basically I'm looking for a way to dramatically improve the flow of the intake, so much so that it can at least kind of compete with those aftermarket ones. Now of course, they're way better and you're never going to get one of these old iron boat anchors to be as good as a modern aluminum one. |
Re: Stock intakes question
Your looking for this guy it seams. http://m.summitracing.com/parts/nal-14096011
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I've seen once were a guy went though extreme lengths to take a performer rpm intake and tig welded all the numbers and such on the intake all to disguise it. Guy was an exceptional tig welder though. Haha. Or do what this other guy I know did haha. Hogging out an intake is much more involved than you would think. You can also look for marine intakes which are cast better and flow a little more as a good starting point increasing plenum up top by using a spacer will help a lot. Making it square bore and making the top look like a performer intake will yield good results. Internally your going to have to deal with the casting as is and maybe port Match and de flash the bottom ends. Block off the egr and heat riser ports and your prob at the max of the intake
![]() Posted via Mobile Device
You want your stock intake manifold or exhaust manifold done. THen you're looking for
"extrude Hone". http://extrudehoneafm.com/ |
I would be almost worried that to smooth of a funish would be detrimental to fuel mixing. It's neat as hell though
Extrude honing helps but you still have poorly shaped runners that aren't the best for power. Keeping in mind that head flow is most important, so if you have aftermarket heads to gain horsepower what does it matter the brand of intake since engine is no longer stock anyway. An improved intake alone on a stocker won't do much, if anything at all.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
I've heard of guys sawing the factory intake in half, porting it, then welding it back together and finishing it so it looks "as cast."
I've also heard of guys capping the intake and filling it with hydrosulphuric acid for a spell. The acid dissolves everything "bigger" and it still looks "as cast" inside. In the effort vs cost end of things, unless I wanted to build a killer "cheater" motor, I wouldn't bother.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#8 | ||||
And then no one would know! WAHAHAHA!!
THe mixing occurs in the carb. Smoothed and shaped runners speed up the mix in to the chamber. THat's why you port and polish. Rough surfaces slow down the mix and tend to seperate it.
Check these guys out for stock appearing cars. THey run some incredible times. http://www.fastraces.org/ |
| Bookmarks |
