1966 Chevy C10
Trying to remove exhaust pipe from exhaust manifold but unable to remove 1 nut from passengers side any ideas?
and a few others
Re: 1966 Chevy C10
You posted in the Pre-47 area, so I moved it for ya
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
![]() Join Date: Oct 2012
Re: 1966 Chevy C10
Hopefully its a brass nut....however, even at that the steel threads on the stud may well be gone.
If mild heat from a propane torch followed by an ice cube quench or a pb blaster quence don't free it up....go with a nut splitter. |
Re: 1966 Chevy C10
Re: 1966 Chevy C10
Thank you, yes its the brass nut. Was able to remove 4 of the 6 no well some problem breaking free, 1 stud did end up breaking and I am still stuck with one on passenger's side. Will try the nut splitter thank you for the advice.
Re: 1966 Chevy C10
may end up breaking, I would soak it with penatrating oil first.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
Re: 1966 Chevy C10
Thank you jhrusk was able to take some time and look at your Sanford build looking great. We did soak it but still had 1 break off.
