Old 08-23-2013, 02:32 PM   #1
gale
gear lube
I need to drain, clean, and refill my 4 speed transmission and Eaton rear end on a '67 C20. Do they use the same oil? Quantities?
Gale Gorman
'54 3100
'67 C20 stepside
gale is offline   Reply With Quote
Old 08-23-2013, 02:37 PM   #2
Lattimer
Lattimer's Avatar
Re: gear lube
Both should be 90wt. No clue on how much. My half ton diff takes about 1-1/2 quarts, car 4-speed takes about a quart.
The Eaton probably requires an additive.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-23-2013, 02:42 PM   #3
Mister-B
Re: gear lube
My Dana 60 3/4 ton took over 4 quarts. Best bet is to buy a 5 gallon jug of Valvoline
As for your transmission, I'm pretty sure it needs Dexron. I used Valvoline Max Life Synthetic, and a bottle of Lucas tranny additive
Mister-B is offline   Reply With Quote
Old 08-23-2013, 02:46 PM   #4
gale
Re: gear lube
The transmission is 4 speed manual with very low ratio 1st gear.
Gale Gorman
'54 3100
'67 C20 stepside
Old 08-23-2013, 02:46 PM   #5
Lattimer
Lattimer's Avatar
Re: gear lube
He said 4-speed, so thats a manual if its original. Dexron is only for autos.
Shawn
Old 08-23-2013, 02:47 PM   #6
Lattimer
Lattimer's Avatar
Re: gear lube
I have always used 90wt in manual transmissions and rear ends, at least up until the newer vehicles started using various other lubes.
Shawn
Old 08-23-2013, 02:49 PM   #7
Mister-B
Re: gear lube
Ah, ok. Gotcha
Old 08-23-2013, 02:57 PM   #8
cdowns
cdowns's Avatar
Re: gear lube
i'd think if you bought a 5gallon jug you'd have at least 4gallons left over??? sounds like typical oil company logic there
me i'd just use royal purple fer everything // no additives needed
Old 08-23-2013, 03:02 PM   #9
Mister-B
Re: gear lube
I meant to say I bought a 5 quart jug and used around 4 of it
Old 08-23-2013, 04:08 PM   #10
SS Tim
SS Tim's Avatar
Re: gear lube
Download the factory manuals if you don't have them. The owner's handbook has a lot of good info there too. These will help you get on track with recommended service fluids and capacities.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 08-23-2013, 04:30 PM   #11
gale
Re: gear lube
Thanks for the link. I wondered where those were.
Gale Gorman
'54 3100
'67 C20 stepside
Old 08-23-2013, 04:46 PM   #12
gale
Re: gear lube
I downloaded the manuals and they do specify 80 SAE at -10F and 90 SAE up to 100F and 140 SAE if the temp is consistently over 100F.
BUT the quantity is "level with fill plug" so we will only know after measuring what's left over.
Gale Gorman
'54 3100
'67 C20 stepside
Old 08-23-2013, 05:14 PM   #13
SS Tim
SS Tim's Avatar
Re: gear lube
Driver's handbook lists; 4-speed @ 8.0 pints, 5200# rear @ 6.5 pints
Old 08-23-2013, 07:04 PM   #14
gale
Re: gear lube
Thanks. That adds up to just under 2 gallons. I can get Valvoline in gallon jugs for $20 from O'Reilly, etc. There's a wholesale oil dealer not far from me and the smallest he sells is 5 gallons. I'll go see how much for a 5 Monday.
Gale Gorman
'54 3100
'67 C20 stepside
