Old 08-23-2013, 06:08 PM   #1
smyers3009
C2500 control arms
Will 1973 and later front control arms, upper and lower, bolt on to my 1969 truck without any modifications?
smyers3009 is offline   Reply With Quote
Old 08-25-2013, 07:03 PM   #2
airdale94
airdale94's Avatar
Re: C2500 control arms
Yes. Are you doing a disc swap or do you just need control arms? The uppers are the same. The only difference in the lowers are the turn stop for disc spindle. The ball joints are different but will bolt or press into either. It's the stud that is different.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
