Old 07-05-2003, 07:06 PM   #1
orange72350
orange72350's Avatar
Pulley Pic questions!!!!
Im putting my rebuilt 350 back together, and i could really use a pic of the proper pully setup. one of my pulleys has a series of numbers on the back, but the numbers end with a bb. does this mean that i have a big block pully setuo? either way, could i see a pic of the proper pulley setup. i wanna make damn sure that i have everything right!! tahnx in advance
dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 07-05-2003, 07:35 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hope this help's you out if you need more I can take more.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-05-2003, 11:05 PM   #3
orange72350
thanx fer tha pic. any chance u could get one with the crank in the pic? i should have said it, but thats mainly whtooking for. thanx in advance
dale
Old 07-06-2003, 12:45 AM   #4
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
here
maybe this will help a bit...
no belts though....
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-06-2003, 01:33 AM   #5
orange72350
thats wicked awesome. thanx fer the pics guys. btw, does the inside belt(closest to the engine) go to the p/s pump nad outside to the alternator/w/p? or am i backwards? i took it apart long time ago and forgot. thans fer the help guys
Old 07-06-2003, 02:11 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The close to the block should be water/alt belt then the little ps belt.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-06-2003, 04:40 AM   #7
Desert Rat
Desert Rat's Avatar
the pulleys in the first picture are truck correct with short water pump.the second pic has a later model long water pump and pulley.If you have the correct set up.you will either have a single row pulley/or double row(if you have AC)the inner pulley is for the alternator,if you have AC its the 2nd,and if you have power steering,and the correct short water pump,it will be a seperate(kind of dished shape pulley)that fits on/in the other pulley.the bb does not mean you have a big block pulley.If you need a picture i email me gmcrat427@yahoo.com,i have several that are off the engine.
if your not sure if you have long or short water pump.short pump your alternator is on the driver side,long pump on pass side,and long pump is a taller pump(like in picture #2)
Desert Rat is offline   Reply With Quote
Old 07-06-2003, 04:44 AM   #8
Desert Rat
Desert Rat's Avatar
Heres the correct pulley for trucks w/o AC
Old 07-06-2003, 04:46 AM   #9
Desert Rat
Desert Rat's Avatar
Heres the PS pulley(its upside down)it fits in the other pulley.
Old 07-06-2003, 04:49 AM   #10
Desert Rat
Desert Rat's Avatar
Heres basically what the inner pulley should look like if you have AC.this is actually a big block one.A quick visual difference is bbc pulleys have a large diameter hole in the middle for the balancer bolt,also the lip on the backside is bigger and wont fit a sbc without grinding it off.If you need the top two pulleys id sell them for $15 plus ship.
Old 07-06-2003, 04:52 AM   #11
Desert Rat
Desert Rat's Avatar
oops!!! bbc one w/AC
Old 07-06-2003, 03:41 PM   #12
orange72350
Right on guys. I thinks I got her figured out. thanx fer all tha help.
dale
