Old 07-05-2003, 07:09 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
1/2-3/4 ton frame difference
I had to put a new frame under my 1/2 ton 72,I replaced it with a 69 3/4 ton frame . I swaped the front cross member,rear trailing arm set from the 1/2 ton on to the 3/4 ton frame. Everything seemes to fit fine but I have heard the frame's are not the same. What's the difference and can I use 1/2 ton bodymount's on the 3/4 ton frame??? Thank's in advance.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-05-2003, 07:19 PM   #2
crazy longhorn
Fabricate till you "puke"
the rear cab mount cushions are different (taller) on the 3/4 ton 2 wds, & also on the 4 wd trucks. the bracket on the frame is also different, so I would just use 3/4 ton cab mounts. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-05-2003, 07:19 PM   #3
Huck
Huck's Avatar
. No expert but---I know that the rear cab mounts on the 3/4 ton are lower then on the 1/2 ton which results in having to use different cab mounts. I would expect that you can use 3/4 ton mounts on your 1/2 ton cab with no problem as long as you use that stratgy all the way thru. The actual frames appear to be the same to me---size, weight, design, etc. Where you get into problems is 4x4 is defferent then 2x4. You also have different mounting between rear leaf springs verses coil. Hope this helps---Huck
Huck is offline   Reply With Quote
Old 07-05-2003, 07:22 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
Thank's for the quick replies..
MEMBER #6377
Project "7DEUCE"
