Old 08-24-2013, 02:08 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Question for Keith Seymore
Keith,
A while back you welcomed me to ask you questions about 73-87 trucks and the engineering behind them.
My first question..
On upper door hinges, why did GM use one bolt threaded in from the inside and the rest from the outside ? As I'm working myself into heatstroke today rebuilding door hinges on a truck, I was struck with the frustration of having to access that one bolt per side from inside the truck while the rest are outside the cab and easy to get to.
Thank you for your time.
Old 08-24-2013, 02:26 PM   #2
Redcap
Re: Question for Keith Seymore
An excellent question, one I am interested in hearing the answer to as well!
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 08-24-2013, 02:28 PM   #3
willett
Another Day, Another Dollar
willett's Avatar
ya! I hate those damn things!!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 08-24-2013, 02:51 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Why are you removing the hinge if you're just rebuilding, ie pins and bushings.
Don't try doing the same thing with newer trucks, it'd really tick you off having to break out your welder and air hammer.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-24-2013, 03:04 PM   #5
Tx Firefighter
A hinge rebuild for me is full sandblast, powdercoat, and reassemble with new pins, bushings, and detent springs. They gotta come off for that.
Old 08-24-2013, 03:35 PM   #6
ont_guy_38
ont_guy_38's Avatar
They are like that so you don,t have to remove the fender to get the one bolt out. That's my guess and I'm sticking to it !!!!!!!!!!
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 08-24-2013, 05:25 PM   #7
RandyP
RandyP's Avatar
I totally forgot about you powdercoating now. I say now, it's been a while now actually.
Can you pretty much create every color under the rainbow with that?
Old 08-24-2013, 05:29 PM   #8
bigblock73
yeller
bigblock73's Avatar
Kevin, what brand hinge rebuild kit are you using? Need to rebuild the ones in my 75, and want a quality kit.
bigblock73 is offline   Reply With Quote
Old 08-24-2013, 05:57 PM   #9
Tx Firefighter
There are right at 6500 colors now. Like your paint, that can turn into millions of combinations. There's all manner of clears from dead flat to full gloss, clears with boat flake metallics, fine metallics etc. Then, the range of translucent colors which you can put over whatever color base you desire to skew the final color to whatever you want. Just like paint, a black base coat and a white base coat, or even chrome base coat with a candy mid coat will vary in color. This is my most popular color. I've coated several dozen motorcycles in it.
Lately I've been pushing the envelope a lot with laying a basecoat, applying stencil graphics in vinyl, then a topcoat, peel stencils, and clear the whole mess. I did this bike for a guy in half and half theme. It's all white basecoat, apply stencils, two different topcoats, peel stencils to expose the white, then lots of clear.
More careful masking with vinyl and multi colors. This is a heat shield on a dirt bike exhaust. I did the ceramic coating on the pipes behind it too.
I ordered the hinge pins and bushings from Classic Parts. They're perfect. Unlike most, the length is right and the pins don't need trimming shorter. I also ordered the S shaped springs that go on the upper hinges to hold the door open. It's all top notch. I pretty much only order from Classic Parts lately for most all of my needs on truck specific stuff. Summit and Rock auto for more generic hard parts.
Old 08-25-2013, 11:56 AM   #10
RandyP
RandyP's Avatar
Damn, that's impressive. Guess I'm just used to hearing powdercoating and thinking black.
Did not mean to hijack your thread man.
Old 08-26-2013, 06:12 PM   #11
Stoney
Farm Truck
Stoney's Avatar
Do you have to remove the front fenders?
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 08-26-2013, 06:36 PM   #12
Tx Firefighter
I did but you don't have to. I wanted to do some other clean up and panel alignment work at the same time so it was much easier to yank the front fenders. Then I rebuilt all of the door stuff and aligned the doors to the cab. Then installed the front clip and aligned it to the doors. I got the gaps very good and the door operating very well, but it wasn't a walk in the park. These trucks suck for door alignment and latching if they have any wear on the parts whatsoever. Don't even get me started with the cracks I had to weld up in the doors.
Old 08-26-2013, 11:31 PM   #13
kelsfine69
18 Till I Die
kelsfine69's Avatar
Candy Ruby Red...I know it well.. .Now back to the question..
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 08-27-2013, 09:22 AM   #14
Keith Seymore
Keith Seymore's Avatar
Originally Posted by Tx Firefighter View Post
Keith,
My first question..
I'm sorry my delay in responding; I'm not sure why I just now found this thread.
I didn't know the answer but I walked a couple rows over and asked one of the old (old) design engineer (he retired from GM and is now back as a contract worker). It's a process oriented thing: one guy shoots the bolt early in the build from the inside to get everything hanging, and then another operator comes along later and shoots all the remaining bolts from the outside.
This type of division of labor is not uncommon, particularly because of work load balance. Often one worker will finger start a nut and bolt and then someone else tightens them. My friend Bill (the guy with the 3 speed GTO) was telling me he used to work at Ford and was responsible to put the "F" and the "O" on the trunk lid. Someone else came along later to install the "R" and the "D".
Poor guys were overloaded. I told him it's a good thing he didn't work for "C-H-E-V-R-O-L-E-T"....
(lol)
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-27-2013, 09:30 AM   #15
Keith Seymore
Another thing that drives these seemingly unusual releases are "monuments" in the plant - large fixtures or pieces of equipment that cannot be moved without great expense and lead time.
An example of this would be on the GMT800 product. On the prior product (GMT400) the battery was located in the RF corner of the engine comparment; the engine air cleaner was on top of the fender wheelhouse and the engine coolant surge tank was at the rear (up against the front of dash).
In this configuration the coolant system could be evacuated and filled without the fender in place, which allows it to happen earlier in the process and allows operators easy access to the engine compartment.
So - new program and along comes a new air induction engineer (..."me"...) with more stringent flow restriction requirements than ever before. It became apparent that in order to minimize bends and overall length, and therefore meet the requirements, I needed to have that front corner for my air box. That meant the battery guy had to go to the front of dash (for structure) and the coolant bottle had to go to the top of the wheelhouse. Only problem with that: we couldn't fill the bottle without the fender there, and couldn't move the fill equipment because it was too huge.
Solution: add two little buttons to the radiator support to allow the coolant bottle to be temporarily "slaved" to the rad support for fill, and then moved to its final position later after the fender is installed.
The next question becomes: what do you do with the little buttons? Leave them on there? Pull them off? Re-use them? In the end we determined it was cheaper just to leave them on and let them stay there for the life of the vehicle.
So - if you look at any GMT800 product you will see those two little buttons still there, going along for the ride, for no apparent reason: All because of a new guy and because we couldn't move the fill equipment.
K
1979-1986
1986 - 2019
Old 08-27-2013, 09:35 AM   #16
Tx Firefighter
Thank you for the thorough answer. I wish I could spend a year in that place. I think I'd learn a lifetime worth every day.
Old 08-27-2013, 09:43 AM   #17
Keith Seymore
I always wanted one of those
(or a Honda 50).
K
1979-1986
1986 - 2019
Old 08-27-2013, 09:44 AM   #18
Keith Seymore
Yep. I wish you guys could follow me around for a year, too. I think you'd be fascinated and astounded.
K
1979-1986
1986 - 2019
Old 08-27-2013, 11:32 AM   #19
kelsfine69
18 Till I Die
kelsfine69's Avatar
(or a Honda 50).
K
I just finished it this spring. I have a Candy Gold one next on the list for a winter build
2011 GMC Acadia
1969 GMC BBC LS7
42000Km
Old 08-27-2013, 11:36 AM   #20
faribran
Keith, we do appreciate the sharing of your knowledge.
faribran is offline   Reply With Quote
Old 08-27-2013, 12:06 PM   #21
S10Fan
Old Heap Driver
Ditto
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 08-28-2013, 03:11 AM   #22
PAWS 72
PAWS 72's Avatar
Yep Keith we do.
PAWS 72 is offline   Reply With Quote
Old 08-28-2013, 10:28 AM   #23
8lugnutz
8lugnutz's Avatar
K
I think I would be astounded after just one hour, much less a year!
1980 Chevy K10 Silverado --> Build Page
My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper.
8lugnutz is offline   Reply With Quote
Old 08-28-2013, 11:36 AM   #24
cory d
cory d's Avatar
i dont put those back on
cory d is offline   Reply With Quote
Old 08-28-2013, 11:38 AM   #25
cory d
cory d's Avatar
also the stupid one the on front of the fender. i leave those off
