Porterbuilt steering rack , question?
Is there supposed to be a crush washer or something else that goes between the rack ,and the fitting that the hoses connect to? I enclosed a couple of pics. Its leaking pretty good between these two connections the pressure and return lines.
Its not leaking between the hoses and these fitting just between the rack and the fittings.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
A day late and $1 short...
Re: Porterbuilt steering rack , question?
Are those fittings provided by Porterbuilt? I appears to have a packing (white Teflon ring) on it already. Do you what production vehicle the rack is from?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
Liquid Teflon. Or yellow Teflon tape around fitting
Ed will be known as the Tiger Woods of the integration business |
So they are pipe thread?
It looks like a pipe thread to me on my iPhone.
Many power steering fittings today are metric o-ring. For instance my truck has a 97 corvette power steering pump witch uses 16mmx1.5 o-ring and mi steering box is an 86 C10 witch uses 18mmx1.5 o-ring. Given the late model look of the rack I would check to see if it in fact need that style fitting, which is made by earls or russell and available at places like summit racing or jegs.
yeah those fittings require teflon tape... my truck they are getting teflon, problem solved.
67-72 parts collector,…
![]() Join Date: Nov 2002
Tapered pipe threads get teflon tape.
Straight threads get a gasket. That white gasket should make the seal,... but Unisteer include Loctite 545 (hydraulic thread sealant) with their AN fitting kit. http://www.unisteer.com/search_by_pr..._fittings.html
Guess I'll try Teflon tape and see if that fixes it.
Danny-
The small teflon o-ring should be sufficient and seal right up. The fittings we supply in the kit are a standard thread to AN fitting that Unisteer makes. Does it feel like they thread into the rack tightly? Or do they feel sloppy at all? Feel free to call us or email directly so we can help you get this leak figured out. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
^^Customer support^^
#12 | |
#13 |
Junior Member
I hear you know a good painter.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#14 |
That I do
