Old 08-24-2013, 07:20 PM   #1
danw210
69 K20
Swapping from 4spd to TH350 issue
I'm making the swap in my 69 K20 from the manual trans and Rockwell to a TH350 with NP205 that I got from a 72. I have the automatic crossmember from the 72 but the trans mount is 2 1/4 inches off from the bracket. Has anyone done this swap? I would guess that the easiest solution is to drill the holes for the bracket into the frame. Am I right or am I missing something?Name:  image.jpg
danw210 is offline   Reply With Quote
Old 08-24-2013, 08:01 PM   #2
JimKshortstep4x4
Re: Swapping from 4spd to TH350 issue
Should be an easy swap. Do you have a 6 cylinder or 8 cylinder engine?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-24-2013, 08:11 PM   #3
70-K5
Yup, drill new holes, easy as that.
70-K5 is offline   Reply With Quote
Old 08-24-2013, 08:20 PM   #4
danw210
69 K20
It's an 8 cylinder Jim.
Thanks 70-k5.
Old 08-24-2013, 10:06 PM   #5
fp1967
fp1967's Avatar
You need to drll new holes, because of the Rockwell transfer case to the NP205 conversion. I had to do this on my 69 going from a 4 speed/Rockwell to a 4 speed/NP205. You will a also need different length driveshafts.
fp1967 is offline   Reply With Quote
Old 11-18-2013, 03:29 PM   #6
Willie496
Will a 454 bolt up to the Rockwell with the 4 speed 4x4?
Does anyone know what changes are needed to make this conversion?
We have a 71 GMC and want to put a 454 in place of the 350.
Thanks,
Willie
1969 GMC 4x4, 4 speed, 350 Fleet Side in progress.
1969 Camaro SS 427 Cortez Silver. owner since 1974
1964 Chevelle 4 Door, 427 Big block,Turbo 400
1/4 Mile 10.52 @ 125.85 mph. 1.39.1 60'
1982 Crew Cab 3+3, 2WD 3.21 Locker, 468/4 speed
1969 C30 4 speed (IL6) future build.
Willie496 is offline   Reply With Quote
