![]() Join Date: Mar 2012
Any body used this type of primer , i have a gallon kit in the garage, but nothing is labeled in english, I was going to use it on another bed i have out back.any info i can get on it would be useful
U-POL 2.1 URETHANE High Build DTM PRIMER ![]()
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Anybody out there??? Helloooooo....
member #16
![]() Join Date: Dec 1999
Re: primer info
You might have better luck the paint and bodywork forum.
http://67-72chevytrucks.com/vboard/f...splay.php?f=16
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Re: primer info
http://www.ebay.com/itm/Qt-Kit-U-POL...d8e996&vxp=mtr
Similar name Quart size
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: primer info
Thanks i guess i need to dig around the website a little more, lots of good info all over the place
