Old 08-24-2013, 08:55 PM   #1
joel.e
joel.e's Avatar
Prothane radiator support mount
So I have the Prothane kit for '67-72 but the radiator support is a different diameter. The urethane mount is larger than the OE hole in the core support bracket on the frame? I searched but didn't find anything. Guess I'll make the frame hole bigger...
joel.e is offline   Reply With Quote
Old 08-24-2013, 09:13 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Prothane radiator support mount
What year truck do you have?
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-24-2013, 09:14 PM   #3
Chevys10dr
Chevys10dr's Avatar
I has the same set, mine were about 1/32 out, I just took a carbide and made it fit snug. For got to add my chassis was a 68 2WD SWB But the body is a 71
Chevys10dr is offline   Reply With Quote
Old 08-24-2013, 09:23 PM   #4
a.c.1
Thats funny..I experienced the same exact problem today..I thought I must have ordered something wrong. I have a 68 swb too. WTH.
a.c.1 is offline   Reply With Quote
Old 08-24-2013, 09:43 PM   #5
joel.e
joel.e's Avatar
Mine is a '67 swb.
Old 08-24-2013, 09:56 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Check out the differences in the mounts.67-68 are different than 69-72.I don't recall the exact differences but someone has listed which to use when changing front sheetmetal.If you use the wrong ones the front sheetmetal will never align properly.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-24-2013, 10:30 PM   #7
Chevys10dr
Chevys10dr's Avatar
Is there a difference the same using stock mounts when using 68 frame and 71 body, if it is that explains the slight misalignment the PO did alot of messed up s*** to the truck.
Old 08-25-2013, 12:40 PM   #8
joel.e
joel.e's Avatar
The box indicates they are for '67-72. Guess I'll make my frame mount bigger like Chevys10dr but mine are closer to 1/8" to small.
Thanks for the replies
Old 08-25-2013, 03:13 PM   #9
cdowns
cdowns's Avatar
i would not use prothane mounts for a street driver vehicle ever again/// most guys with daily type triucks dump them within 3months of installing them
Old 08-25-2013, 03:26 PM   #10
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I agree, stock rubber type are the way to go. The Poly ones tend to squeak.
--Josh
