Old 08-24-2013, 09:10 PM   #1
buddylj1990
i have problems again clutch linkage question
i have v8 in my truck sbc and the bell crank also called z bar cracked (for those that don't know like me im talkin about bracket that bolts from frame to engine for clutch linkage) i have access to one off a straight 6 truck will it work
buddylj1990 is offline   Reply With Quote
Old 08-24-2013, 10:23 PM   #2
Lattimer
Lattimer's Avatar
Re: i have problems again clutch linkage question
It should. Only difference is in the brackets, z bars should all be the same.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-24-2013, 10:30 PM   #3
beetle1960
beetle1960's Avatar
they are the same
beetle1960 is offline   Reply With Quote
Old 08-24-2013, 10:42 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Six cylinder Z bars are longer between the frame and block pivot ball than small block ones by about 1/2 an inch.
Old 08-24-2013, 11:45 PM   #5
buddylj1990
thinks was drivin home from work when clutch pedal quit pulled over in bad part of town and found it had cracked on the side so i didnt want to leave truck there so drove it home shifting it by rpms thats hard as hell doing that on a 3 speed truck on the column had to stop a few times shut it off and start again
Old 08-25-2013, 06:55 AM   #6
scott-wisc
scott-wisc's Avatar
I am doing a 6 cyl to 350 swap and am looking at a hydraulic clutch conversion.
scott-wisc is offline   Reply With Quote
Old 08-25-2013, 09:34 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=Tx Firefighter;6237130]Six cylinder Z bars are longer between the frame and block pivot ball than small block ones by about 1/2 an inch.
/QUOTE]
And it would be suuper easy to cut that excess length off with a hacksaw.
Tom Vogel is offline   Reply With Quote
Old 08-25-2013, 01:34 PM   #8
Tx Firefighter
[quote=Tom Vogel;6237563]
/QUOTE]
Yes. When I convert from six to eight that's what I've always done.
