Old 08-24-2013, 11:29 PM   #1
steves1967
steves1967's Avatar
Side trim install??
I tried the search but it isn't working... How do you install the side trim (lowers) with those clips? The LMC website shows all the clips, but not how they hold the trim in place and i'm scratching my head.
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 08-24-2013, 11:40 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Side trim install??
The clips twist into the backside of the molding, and there are holes in the body that they go through. Some are bigger holes for push in clips, and others are smaller holes that use clips with speed nuts on the backside. Typically the end clips have nuts, and the ones in between are push in.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-25-2013, 06:25 AM   #3
Square_78
Square_78's Avatar
Do you have the holes drilled in the body from the factory or are you using the adhesive clips? I didn't even use clips. I used silicone glue to hold mine on. Very strong and will never fall off.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 08-25-2013, 07:28 AM   #4
nobolt
nobolt's Avatar
the clips "twist" into the molding, and then put the molding (with clips installed) onto the side of the truck.
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 08-25-2013, 04:00 PM   #5
steves1967
steves1967's Avatar
ok, think I got it. Ordering all new clips now- my truck has the lower moulding already attached- mine is the wood grain and I want to switch over to the black.
'22 Chevy Tahoe RST
