Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-25-2013, 01:37 AM   #1
jd21476
jd21476's Avatar
Are the antennas any good???
I just installed my Alpine stereo in my 73 and hooked up the antenna wire I found under the dash. The reception for the radio was not great and would cut in and out. I stopped for gas and when I restarted the truck the tuner was just static. The antenna was still plugged in and everything else on the stereo worked.....CD, Bluetooth, etc.
Since I don't see an external antenna I can only assume it is in the front windshield. Anything else I need to check?
jd21476 is offline   Reply With Quote
Old 08-26-2013, 01:46 AM   #2
bigwheel15
bigwheel15's Avatar
Re: Are the antennas any good???
Make sure the antenna is still connected to the button on the bottom of the windshield. It could have came loose.
bigwheel15 is offline   Reply With Quote
Old 08-26-2013, 01:34 PM   #3
_Ogre
_Ogre's Avatar
probably not connected to an antenna
if you don't have an antenna hole, like my shaved truk
i bought a $10 autozone antenna and mounted my it under the truck
works fine
shop air compressor timer
Old 08-26-2013, 01:47 PM   #4
jd21476
jd21476's Avatar
works fine
Was it one of those powered antennas?
Old 08-27-2013, 02:14 PM   #5
_Ogre
_Ogre's Avatar
for $10
nope just the cheapest antenna i could buy
in your location it will only pick up a hundred or two stations
Old 08-27-2013, 05:05 PM   #6
jd21476
jd21476's Avatar
I'll check that tonight
1973 Chevy K20
Old 08-30-2013, 09:42 PM   #7
jd21476
jd21476's Avatar
So it turns out that I had the wrong antenna plugged in. The PO at some point must have had an aftermarket antenna. I grabbed the wire under the dash and plugged it in without tracing it back. It was cut and ran to nothing.
I found the one that runs to the windshield and now it works great.
1973 Chevy K20
