Old 08-25-2013, 01:33 PM   #1
IronAnRkst
Found Rust :(
So got the flooring crap pulled out and I got rust in the floor, it's not eaten through or real weak but its further than surface.. So any ideas on what my options are here before I order my stuff to redo the carpet and such.. Heres where I am at now...
http://i947.photobucket.com/albums/a...psbad9da5a.jpg
http://i947.photobucket.com/albums/a...psa864c552.jpg
IronAnRkst is offline   Reply With Quote
Old 08-25-2013, 01:34 PM   #2
IronAnRkst
Re: Found Rust :(
Sorry forgot to put em in the right way.. lol
Old 08-25-2013, 01:35 PM   #3
tinydb84
tinydb84's Avatar
Re: Found Rust :(
that doesnt look too bad to me. Id wire wheel it and use some por15
David
Instagram: myfabguy
Old 08-25-2013, 01:38 PM   #4
IronAnRkst
Re: Found Rust :(
Ye it hasnt got to where its real soft or pushing through but I wasnt sure if sanding it down as good as I can would be good enough or if there was something else I needed to do, this is more or less my first time doing this kind of stuff. Got a little experience in a few things but not necessarily done them in a car so its all a learning experience for me..
Old 08-25-2013, 01:44 PM   #5
dieseldawg142
dieseldawg142's Avatar
Re: Found Rust :(
yup, wire wheel it, sand it, por 15 it.
check out post #2 & #7, before & afters, pretty much like yours
http://67-72chevytrucks.com/vboard/s...d.php?t=559596
dieseldawg142 is offline   Reply With Quote
Old 08-25-2013, 01:47 PM   #6
tinydb84
tinydb84's Avatar
Re: Found Rust :(
^^^this is what you should do to make your truck WAY quieter inside. I will be doing the same in mine.
David
Instagram: myfabguy
Old 08-25-2013, 02:06 PM   #7
IronAnRkst
Re: Found Rust :(
Thanks diesel, did look just like mine.. So looks like that will be the route I will go.. As far as noise mine isnt too terribly bad, but it also had the original floor stuck rusted into the floor which felt wet i guess just soaked in, then some pink matting on top of that then the vinyl covering. Now its just down to metal. lol
Old 08-25-2013, 02:11 PM   #8
IronAnRkst
Re: Found Rust :(
Cant seem to find the wire wheel I used to have so just a quick question before I run to the store and get dumbfounded.. lol. I had 1 of the ones that had like the brass wires on it, are their different ones or a certain kind or style that would work better than another??
Old 08-25-2013, 02:28 PM   #9
dieseldawg142
Re: Found Rust :(
grab some flat ones & some cupped ones, cheapies are good enough, there just gonna get wrecked anyways.
if you go the por 15 route, spray their Prep & Ready liberally on the floor & keep it wet for at least a half hour. will convert what rust is left & etch the metal for a really good bite.
oh yeah, you might want to cover EVERYTHING in your shop, unless your outside, & a mask to stop the brown boogers
Old 08-25-2013, 03:08 PM   #10
IronAnRkst
Re: Found Rust :(
Went and got a 4' Coarse Flat one, so guess I am gonna go to wearing down with that, maybe I can order the POR-15 next weekend, Think one of them starter kits they have for 21 bucks would be enough for what I need to do?
Old 08-25-2013, 03:28 PM   #11
dieseldawg142
Re: Found Rust :(
well, my trucks a crew & i bought a quart & put down 3 coats. i think i had just under half left
Old 08-25-2013, 03:57 PM   #12
IronAnRkst
Re: Found Rust :(
Well got the passenger side pretty good as far as the wheel goes til i hit it with the sander, but I did have a few small holes and one about thumb size in the back left corner but other than that not too bad considering what I could have ended up with, will post pics when I get done with the driver side, well back to it
Old 08-25-2013, 06:06 PM   #13
IronAnRkst
Re: Found Rust :(
Okay so after the wire wheel....
Passenger Side
Driver Side
Old 08-25-2013, 07:59 PM   #14
mgchevyparts
mgchevyparts's Avatar
Re: Found Rust :(
POR is just paint, use some metal prep (2% or so acid) remove the rust, neutralize then paint POR or what ever. Most importantly fix the leak(s), usually leaking windshield gasket and side window and door gaskets.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 08-25-2013, 08:11 PM   #15
Rannos
Rannos's Avatar
Re: Found Rust :(
If you buy the entire kit. Por 15 comes with a metal cleaner and a treatment. You don't need to mm use anything else.
Rannos is offline   Reply With Quote
Old 08-25-2013, 10:29 PM   #16
1slo_camaro
Re: Found Rust :(
rust inhibitor. i would also crawl underneath and coat that as well. because if you just coat the top its not going to protect it from the enviroment underneath.
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 08-25-2013, 11:19 PM   #17
dieseldawg142
Re: Found Rust :(
so true! when i had my cab off, i stripped the bottom & put 2 coats por 15 & 2 coats chassis black on it. keeping my cab rust-free for a long time
IronAnRkst, floors looking good. a little bit of mig work, or some epoxy putty & your good to go.
http://www.por15.com/EPOXY-PUTTY_p_54.html
