Old 07-05-2003, 10:32 PM   #1
My Boy's Toy
700r4 ?
What TV Cable mounting bracket are you guys using & What was it off of? If any one has a pick it would be helpful . also what is the best place to pull power from , does it need to be fused & what size? thanks
My Boy's Toy is offline   Reply With Quote
Old 07-06-2003, 03:36 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I got mine from Auto Zone. Its made by Spectre and it was around $20. Nice thing about it, it's adjustable...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-06-2003, 07:13 AM   #3
My Boy's Toy
Thanks chuck I'll check them out , where did you tie the hot wire in at ?
Old 07-06-2003, 11:11 AM   #4
Slammed67
Progress = 0%
Slammed67's Avatar
Spend a little extra money and get one of these systems....... works great!
Bowtie Overdrives TV cable
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 07-06-2003, 11:41 AM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
I just bought mine from the dealer, both the bracket and cable for an '80s pickup with a carbbed small block.
Power can be from anywhere you get 12V while it's running. Doesn't need to be fused IIRC.
Might wanna check out the 700R4 FAQ while you're at it.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 07-06-2003, 07:38 PM   #6
Don Smith
P/N 25515598 Throttle valve cable @ $20.00 and Bracket P/N 22504927 @ $17.00 (GM) . Bracket has oppenings for accelerator cable and for the T.V. cable and bolts to back two bolts on Quadrajet.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 07-06-2003, 08:18 PM   #7
My Boy's Toy
thanks guys , & Don for the part # 's that helps.
Old 07-06-2003, 08:34 PM   #8
Project1970
14.1 @ 96MPH
Don: I'll throw those P/N's in the FAQ, thanks!
Old 07-06-2003, 08:43 PM   #9
orange72350
orange72350's Avatar
Stupid question, but what is a tv cable for? what does tv stand for? not television i dont think!!!
Thanx Dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 07-06-2003, 10:39 PM   #10
Slammed67
Progress = 0%
Slammed67's Avatar
TV = Throttle Valve. The TV cable "tells" the trans when to shift.
Old 07-06-2003, 11:45 PM   #11
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
don smith,
do you have any pictures of your set up?
tommie is offline   Reply With Quote
Old 07-07-2003, 01:16 AM   #12
Low69CST
I've got a Lokar set up.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-07-2003, 10:23 AM   #13
fatfords
fatfords's Avatar
On my '72 I used the brown/white wire for the TCS solenoid (solenoid removed by PO). Not sure if your -69 has the same circuit or not. The wire had a disconnect ~12" from the main firewall connector and was routed in the "gutter." The circuit shares a 4 amp fuse with the radio (stock) and has been working fine for several months. The solenoid doesn't pull that much current, but I would recommend protecting the wire with a fuse of some sort since it is a 12 V source.
Good Luck!
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 07-08-2003, 08:41 PM   #14
Don Smith
I have pictures of my setup. Will attempt to scan and post later in the week.
96 Impala SS
97 Monte Carlo
