08-25-2013, 02:27 PM | #1 |
Cluster King
AC Compressor Questions
I am looking to get the AC working on my 72 Cheyenne and have some questions.
First of all, I will say, I am putting the parts together to make this 100% original as it came in 1972. I know they are prone to problems but I am OK with that. I am searching for a compressor and wondering what other compressors will work? I have what I believe is a compressor from a 1978 pick up and other than the factory ID sticker, it looks to be the same. Thank you for your time. |
08-25-2013, 04:46 PM | #2 |
Re: AC Compressor Questions
If you have the long comp., the A-6, they are everywhere in used condition & are pretty much all enterchangeable. The pulleys can vary & clock position of the clutch wire connector can be different. These can be changed with the proper tools. If the 78 is the short R-4 comp. then it is not original to the 72.
08-25-2013, 04:54 PM | #3 |
If you want a good reman A-6, get one that was done in the USA. They are the only ones I have found that won't lose the seal in a year.
08-25-2013, 05:20 PM | #4 |
There is a ten piston direct interchangeable compressor that guys say is the shizz. I think it's called an A-10.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-25-2013, 06:19 PM | #5 |
They don't look original.
08-25-2013, 06:21 PM | #6 |
The problem is he wants it to be "100% original"
But if you paint it black most people wouldn't know the difference. I bought mine from Amazon
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-25-2013, 07:48 PM | #7 | |
Cluster King
