08-25-2013, 07:52 PM | #1 |
a/c heater selector switch cables
Not sure if this is the right area for this question or not. Im new to this forum thing. I am looking for a schematic for the selector switch cable locations. I took it apart and of course didnt pay attention. If anyone can help I would appreciate it.
I dont think so, I know so. |
08-25-2013, 09:38 PM | #2 |
Re: a/c heater selector switch cables
bottom one goes to the outside of the firewall (cable with only one fixed end on it.) Top one goes to the heat/defrost at the floor boards (longest cable). the shortest cable goes in the middle and goes to the plastic piece that mounts closest to the heater core with the compressor switch. Hope that makes sense.
08-25-2013, 09:52 PM | #3 |
I just got down there and looked at there the cables went and figured it out, started by figuring out which cable activated the fan motor, hooked it up, turned on the key, then which one moved the flapper to direct air to the defrost or floor.. process of elimination
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-25-2013, 10:45 PM | #4 |
Thanks guys for the quick response. Now I can finish without the guess work.
07-10-2014, 09:16 AM | #5 | |
Knuckle Buster, Instructor
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
