08-25-2013, 08:10 PM | #1 |
power steering line cooler
for those who have lines hooked up trying to figure out high pressure side on power steering box and low side and where to place cooler low side or high instructions say it should be on the low side thanks for your help
08-25-2013, 08:13 PM | #2 |
Re: power steering line cooler
#2 is the high pressure.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-25-2013, 08:18 PM | #3 |
thanks do you know were i should run the cooler from high or low
08-25-2013, 08:42 PM | #4 |
Run the cooler on the return side
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
08-26-2013, 01:46 PM | #5 |
meowMEOWmeowMEOW
Hook the low pressure line to #3, run that to the cooler, then to the return on the pump. This is a little different if you run hydroboost.
I see those manifolds flipped and facing forwards......you got big plans eh? Only 1 reason to do that
