Engine Mount Questions
Working on the 61. Curently have a 79 crossmember installed. We have a Gen 1 350 chevy, with a powerglide tranny. thinking of using this style mount. The pic is below.
Note, this is the only pic I could find. The ones we will run will have rubber isolation blocks. Any thoughts question comments questions or concerns
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
Re: Engine Mount Questions
if you used the 79 cross member and brackets the why not use the engine mounts out of the 79?
I tried to get them at NAPA. The 79 frame mount is wider than the 92block mount
60-66 Nut
![]() ![]() Join Date: Mar 2007
There are a couple ways to go. One is to use the motor mount brackets for a '67-'72 with a small block as well as the motor mounts themselves. You may or may not have to add a 1/4" or so spacer on top of the frame. My measurements show no spacer is needed. Others have said that a small spacer is needed.
The other option is to use the motor mount brackets from a '73-'87 C20 or C30. Those will fit the early frames better than the C10 brackets. There again a small spacer on top of the frame may be needed. Then you just use the '73 and up motor mounts, and then any upper bracket (clamshell) will work.
Thanks Capt Fab,
I have the clam shell style mounts from the newer block. I was looking for the lower half that mounts to the frame. With your information, I should be able to walk into NAPA and ask for a newer mount. They did pull a mount for me and the ears were wider that the clamshell block side (lower ones shown in the picture). As far as a spacer, if its only 1/4 inch I can make something up. I see that you make power steering and brake booster brackets, Ill be ordering some within the next few months. Thanks for the info
![]() Join Date: Mar 2005
[QUOTE=Captainfab;6238873]...The other option is to use the motor mount brackets from a '73-'87 C20 or C30. Those will fit the early frames better than the C10 brackets. There again a small spacer on top of the frame may be needed. Then you just use the '73 and up motor mounts, and then any upper bracket (clamshell) will work.[QUOTE]
That's what I did. My spacers wound up being 1/4" thick. I tried to use everything I could off of my donor truck (1979 Suburban). I like the clamshell style mounts better than the earlier styles, and every parts store out there carries them.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
