Old 08-25-2013, 09:45 PM   #1
1986brownjl
motor wants to stay on
I have a 86 chevy k10 when I turn the truck off the motor acts like it wants to stay on, like it will turn over a few times after I turn the ignition off. is that the carb? it has a stock quadrajet on it and what size cfm is it to? thanks for the help.
1986brownjl is offline   Reply With Quote
Old 08-25-2013, 10:00 PM   #2
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: motor wants to stay on
I'm sure someone that has a lot more knowledge then I will jump in...but I would check the "anti-dieseling" solenoid on the carb if the truck has one, or the timing may be off slightly.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 08-25-2013, 10:03 PM   #3
cleansquare
Its called dieseling...what rpm does you truck idle at? Could be too high
cleansquare is offline   Reply With Quote
Old 08-25-2013, 10:08 PM   #4
SamsAutoParts73-87
Also worth in investigating, your emissions label on the radiator support will tell you what RPM it should idle at, it should give one for manual trans and one for auto.
-Sam
Old 08-25-2013, 10:15 PM   #5
V10farmboysdream
I'd start with timing. To far advanced will cause a diesel. Crappy gas and high compression will do that too and comes with a spark knock
V10farmboysdream is offline   Reply With Quote
Old 08-25-2013, 10:45 PM   #6
geezer#99
geezer#99's Avatar
Turn your idle down. If it idles too slow then just hook your vac advance to manifold vacuum to speed it back up.
geezer#99 is online now   Reply With Quote
