Old 08-26-2013, 02:18 AM   #1
jdougla9
fender well headers
Anybody have these on an older AD truck with IFS? I swapped out the straight axle for a No Limit Ifs kit and I used headers off my chevelle for the small block. They fit but there really close to the frame. I was wondering if the S10 fenderwell headers would work or if anybody else had some ideas? I love the way fenderwell headers look and give easy room for changing spark plugs etc.
jdougla9 is offline   Reply With Quote
Old 08-26-2013, 06:28 AM   #2
xpickup
xpickup's Avatar
Re: fender well headers
jdougla9, I am using a set of frender well headers from speedway. They were not s10 but just said fender well. I will put the other side on and post pictures tonight if you like.
Shannon
xpickup is offline   Reply With Quote
Old 08-26-2013, 11:46 PM   #3
jdougla9
yes that would be great i think i know what ones you are talking about http://www.speedwaymotors.com/Dougs-...ain,25015.html
I was thinking these would work.
Old 08-27-2013, 08:48 PM   #4
xpickup
xpickup's Avatar
Jdougla9, here are the pictures of the fender well headers. There is plenty of room as you can see. If you need any other angles let me know.
Shannon
Old 08-28-2013, 08:05 AM   #5
spikey
I used the Hedman Hussler 65853 on my 54 with a jag IFS and 350 sbc
spikey is offline   Reply With Quote
Old 08-28-2013, 08:40 AM   #6
xpickup
xpickup's Avatar
spikey, they look like they will work also. I like how they tuck closer to the frame. How are they with the steering?
Shannon
Old 08-28-2013, 09:02 AM   #7
spikey
The steering column runs between the back two tubes, loads of clearance
Old 08-28-2013, 05:29 PM   #8
Gabbyp
I noticed from the photos that the collector points straight down. How would you make the turn to run the exhaust parallel to the frame towards the rear. Again from the photos a 90 deg collector bend looks like it would place the rear pipes way below the frame. I'm sure there a style that would clear the frame like the firewall style that would point the collectors towards the rear. Any ideas. Thanks
Gabbyp is offline   Reply With Quote
Old 08-30-2013, 08:13 PM   #9
vht
Has anyone tried the chevy 2 fenderwell headers by hooker? Chevy high performance magazine has a set on a engine build they're doing. They turn back 90 degrees with street hook ups. If they didn't stick down to far it looks like they would work pretty good.
vht is offline   Reply With Quote
Old 08-30-2013, 08:21 PM   #10
OrrieG
OrrieG's Avatar
Weld a collector flange on the header, do the same on a bent transition to tail pipe. For the street they usually came with cap on the main pipe, with the street exhaust welded to the inside of the large collector.
OrrieG is offline   Reply With Quote
Old 08-30-2013, 11:43 PM   #11
G&R's57GMC
G&R's57GMC's Avatar
Gee that would make hooking up side pipes a breeze
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 08-31-2013, 07:50 PM   #12
vht
The Hooker headers I referred to are pt. no. PN2214HKR. They have a good pic of them in the Chevy High Performance Nov. issue. I may have to try these on mine if I ever get to that point.
Old 09-01-2013, 12:53 PM   #13
spikey
I cut the collector right back and welded on a 90 degree bend. This goes to a QTP exhaust cut out which exits pointing down inside the front fender. The day to day exhaust is tee'd into the back of the 90. Gives around 4" ground clearance
