Old 08-26-2013, 06:18 AM   #1
scott-wisc
scott-wisc's Avatar
RPM Air Gap
Is anyone running this intake? I'd like to order a 5" air cleaner but I don't know if I'll have the clearance. The engine isn't in the truck yet, so I can't check it myself.
scott-wisc is offline   Reply With Quote
Old 08-26-2013, 06:27 AM   #2
Square_78
Square_78's Avatar
Re: RPM Air Gap
Small block? Big block? What carb and will it allow for a drop base air cleaner style? ... Your guess is as good as mine.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 08-26-2013, 06:43 AM   #3
jjzepplin
jjzepplin's Avatar
Re: RPM Air Gap
I have one on my small block 406 with a 2" spacer and Holley 675cfm and Eddy triangular K-N type air filter. Not sure if this will help as my engine is 2" forward now. Fender wells are still not installed yet so I could remove the air filter and get a measurement for you...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-26-2013, 09:19 AM   #4
geezer#99
geezer#99's Avatar
Re: RPM Air Gap
Are you gonna use it in the winter or colder months. If so your motor will run like crap with a cold intake until it gets up to full operating temperature.
Old 08-26-2013, 10:31 AM   #5
eldogg
eldogg's Avatar
Re: RPM Air Gap
Yeah it should fit no prob. I have ran 6" air cleaners with Performer RPM. Just use a drop base and you'll be fine.
eldogg is offline   Reply With Quote
Old 08-26-2013, 05:47 PM   #6
hayhauler71
hayhauler71's Avatar
Re: RPM Air Gap
mine does
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 08-26-2013, 06:05 PM   #7
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: RPM Air Gap
^^I think that air cleaner is almost big enough! ^^
--Josh
Old 08-26-2013, 09:58 PM   #8
scott-wisc
scott-wisc's Avatar
Re: RPM Air Gap
Edlelbrock carb, drop base air cleaner. I'm gonna order a 5". Thanks for the input.
Old 08-27-2013, 11:00 AM   #9
70-K5
Re: RPM Air Gap
I used an offset bottom to move the air cleaner forward to clear the firewall.
http://www.summitracing.com/parts/spe-4768/overview/
70-K5 is offline   Reply With Quote
