Old 08-26-2013, 11:05 AM   #1
blazer2007
78 hood hinges
Well I finally tacoed my first hood,was wondering if the aftermarket hinges and springs any good or ?. The search isn,t working so I couldn,t find any other threads.
blazer2007 is offline   Reply With Quote
Old 08-26-2013, 03:10 PM   #2
superwade57
Re: 78 hood hinges
Imo just keep the gm hinges and keep em lubed. Had a truck get stiff once wd40 and better than new. Also I like to push In as much as pull down on these hoods helps prevent taco. Just don't bolt those silly stiffeners on your hood you'll end up beheaded.
superwade57 is offline   Reply With Quote
Old 08-26-2013, 03:21 PM   #3
frog210
Re: 78 hood hinges
Use your factory hinges, and use electrosis to clean out the rust
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 08-27-2013, 04:20 AM   #4
78trk
Re: 78 hood hinges
I have had 2 out of 3 after market hinges that did't line up very good. I just recieved a right hand GM hinge from Classic Ind. The right side was a lot cheaper than the left. After taking the after market hinge off 3 times and grinding out the holes and the hood was still to high. I wanted the real thing. It works great.
78trk is offline   Reply With Quote
Old 12-20-2013, 05:07 PM   #5
cool68
Re: 78 hood hinges
Sea Foam Deep Creep lubricant might help too
cool68 is offline   Reply With Quote
