Vintage Air losing charge
Ok, I've had my system installed now for 6 months and have yet to get to enjoy it for more than a full day. Initial charge didn't last overnight, took it back to my buddy(an industrial HVAC guy who's been doing it for 20 years). We introduced the dye into the system with next charge, none shows and still leaks out overnight to the point where compressor wont engage. Take it back, charge again... Used soap bubbles this time at every connection, still no luck, leaked out overnight. Anybody here have any suggestions on where I should go from here? Cant get a good referral from anyone here in town on who to take it to try and detect where my leak is. I'm about to pull what little hair out that I have left! I have another co-worker that works in our HVAC department who said he can charge it with R-22 and he should be able to see the leak. Does this even sound like a good idea? I don't know.
Re: Vintage Air losing charge
I would take it to a shop that has a sniffer to detect the leak. Going to have to take out the glove box to better access the rear of the unit.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
If they put dye in it you should be able to see it with a black light. AC leaks are one of the easiest things to find, especially with dye and a black light. Try that but look at the system with the black light in the evening where more dye will show. Also check the AC drain, if evaporator is leaking and system has run enough to condensate you will see traces of dye in the drain tube. Good luck man.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
I've never had the glovebox installed. Yeah, I've been told to find someone with a sniffer.
#5 | |
they used to have sniffers available.... no die needed.
Ed will be known as the Tiger Woods of the integration business |
i would call vintage air for customer service tech
I called them, they said yeah, sounds like you've got a leak somewhere.
![]() Join Date: May 2012
have you tried to pull a vacuum on the system and see if it will hold a vacuum over night, a lot of the time when no leaks can be found, the compressor can be suspect. a good leak detector should find the leak .
The sniffer will get you in the general area. The dye is 100% correct every time. Hope you find it man.
If it leaks overnight, it wont hold a vacuum.
#11 | |
I sure hope it is something like that, I can send it back to Vintage Air before my warranty is up, the system is brand new and it sure sucks not to be able to use it. |
Use dye and a sniffer. That's a large leak to lose it overnight.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#13 |
My '72 that I had had a nasty leak. It would hold vacuum for over 24 hours. It wouldn't hold freon for more than 2 hours. Turned out I had a loose fitting. Somehow the vacuum sucked the o-ring in tight enough to hold but pressure blew by.
#14 |
check the shaft of your compressor. i have seen them leak brand new out of the box. it will sling the dye and you wont be able to see it.
#15 |
![]() Join Date: Sep 2005
It probley leaking from the seal from behind the clutch on the compressor
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#16 |
Agree
#17 | |
Posted via Mobile Device |
