Old 08-26-2013, 11:38 PM   #1
Chmorro
Rear window sliding
I'm new to this forum, but great stuff thus far! I've got an '83 Silverado and the rear window slides open, but its tough to slide. Any suggestions to ease the sliding process? Cleaning or lubing tips?
Chmorro is offline   Reply With Quote
Old 08-27-2013, 12:18 AM   #2
dieseldawg142
dieseldawg142's Avatar
Re: Rear window sliding
clean & lube the track, also check that the track rails aren't bent in. my mastiff, leaning in the cab all the time bent the window frame inward, pinching on the window
welcome!
Last edited by dieseldawg142; 08-27-2013 at 12:28 AM. Reason: thought it was WA, not VA
dieseldawg142 is offline   Reply With Quote
Old 08-27-2013, 12:43 AM   #3
Chmorro
Any suggestions for a type of lube to use on the track?
Old 08-27-2013, 02:50 AM   #4
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
If you followed dieseldawg's advice and the track rails are square and plumb, use silicone (not WD-40!) and see how that works. If there isn't much of an improvement, head over to your local hardware store and get the lube they use for the sliding glass doors in your house. I believe it has beeswax in it. Works like a charm.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
