08-27-2013, 12:17 AM | #1 |
Who has old-style steel rallys on a 99-06 2wd
The search function won't work for me tonight and I looked through some of the 99-06 pics and found one but it's a 4x4.
I'm talking about the 70s and 80s style 6-lug 4x4 wheels that are 15x8s. |
08-28-2013, 01:32 PM | #2 |
Re: Who has old-style steel rallys on a 99-06 2wd
I am anxious to see if anyone comes up with some pics too, Cris. I posted a while ago on this same topic and have yet to see anything from anyone. I am seeking anyone who has been able to mount these 15" rally's on the 99-up trucks. I would love to replace my stock aluminum 16" rims with the old school 6-bolt deep dish rally's on my 2000 2wd - something different, yet a classic look that would be rather affordable compared to other wheel options. Anyone?
08-28-2013, 04:20 PM | #3 |
Here is the 4x4 that I found pics of.
He used later model center caps on them. I kinda like the old caps myself. All 4 rear caps without the hole in them. |
08-28-2013, 08:10 PM | #4 |
It's not possible at all on 05-up trucks. The front brakes are too large and require a minimum 17" wheel. The99-4 trucks can run these if you have rear drums. They will actually fit the front wheels fine, but the rear disc brake caliper requires 16" wheels.
08-28-2013, 11:30 PM | #5 |
Thanks 68Stepbed.
The truck I'm looking at is a 2002. What year did they start putting rear discs on them? |
08-29-2013, 06:16 AM | #6 |
laying low
Rear disc brakes were an option. My 2000 GMC has them. My 2003 Tahoe has them.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-29-2013, 01:31 PM | #7 |
I have rear disc's on my 2000 as well. I looked at the front set up and it looked like a 15" rim would be very tight over the calipers and tie rod ends but now I hear it's the rear that would be the issue. I have heard one can "grind" the calipers to get the wheels to fit. Probably not a recommended practice but I understand it's doable...
08-29-2013, 11:48 PM | #8 |
Fabricate till you "puke"
If you like/want that style wheel....look into the aftermarket, & go 16" on the wheel? My 02 has discs front/rear, & I have to agree, there is not enough room for a 15"' wheel Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
