08-27-2013, 12:17 AM | #1 |
Simple? What's simple?
Engine rattle - 3500RPM or so
Guys, I'm pretty stuck on this one, so hoping somebody might have some insight:
1972 C3500 GMC, 350 with 4 speed, PS. No A/C or A.I.R. stuff. Does have the standard stove pipe riser on the driver's manifold I get an irregular rattle coming from the motor above ~3500RPM ... best guess, no tach. It occurs under any load condition or throttle position, appears to be entirely RPM dependent - no noise at low RPMs, noise at high RPMs. Doesn't vary with RPM once it starts, at least that I can detect. It sounds not entirely regular, like it's not a rotating part. I'm thinking potentially the heat riser pipe / manifold shield, or something to do with the exhaust? I can't seem to find anything, though. The motor runs as smooth as glass, has 50k miles original on it, never been opened. Hardly burns any oil, everything looks clean inside so far as I can tell. It will make it more or less continuously driving on the highway - I start hearing it at 65 and it doesn't really change with RPM above that. Any ideas? Thanks in advance.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
08-27-2013, 01:01 AM | #2 |
Re: Engine rattle - 3500RPM or so
Detonation maybe?
08-27-2013, 07:44 AM | #3 |
08-27-2013, 08:48 AM | #4 |
Cluster King
This is under a load only? Will it happen if you just rev the engine up in neutral? You say it does it at 65 and over? What happens if you are going 68 and put it in neutral and let your foot of the clutch and coast?
The weirdest things cause rattles. A loose piece of trim under a load at the right speed will make a noise. I have seen brake lines buzz if they are not attached correctly. You may need to have a second person wit you to isolate where the noise is coming from. Sometimes what sounds like under the hood is actually back by the tail gate. |
08-27-2013, 06:38 PM | #5 | ||
I've been avoiding revving it enough to rattle if at all possible, I've seen what knock can do Quote:
08-27-2013, 07:29 PM | #6 |
Your distributor might be toast , or someone may have put the wrong vacume advance canister on , they make several , 6 or 8 degrees initial advance is defiantly not alot , sounds like stock . one cheap thing to check is get a avdance tape put on you balencer , and see what kind of advance you have at 3000 rpms , should be around 32 degrees and not climb after that , a distributor with alot of miles on it can sometime ware , and you can get too much advance
08-28-2013, 11:19 AM | #7 |
Rusty Nuts
look at the bottom of your drivers side exhaust manifold and see if the spring tensioner is off of the heat riser or weak, i had this issue years ago and that was it. I removed the peice compleatly and went with straigt exhaust. Did not need it anyway because i changed carbs.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
08-28-2013, 11:45 PM | #8 | |
I gave it a tank of 91 tonight, which it did like, but no change in the noises. I will update once I take a look at the exhaust.
08-31-2013, 12:13 AM | #9 |
There is no exhaust valve on either side in this truck. There is an exhaust shield of some sort on the driver's side manifold which is rusty and not well attached - thinking that is probably my culprit?
08-31-2013, 01:43 AM | #10 |
Rusty Nuts
Could be, let us know if that's what it was.
01-22-2014, 02:08 PM | #11 |
Holy old thread! I just realized I never updated this.
I am getting a rattle from the heat riser (though minimal) - the scary noise I was hearing was a combination of a loose fan and a loose alternator belt. Fixed that, noises gone. Now that fixed blade fan sounds like a small airplane on the highway, though...
