Parking brake location
Hey I've got a 72 chevy w/ no parking brake assembly or cables. Got the assembly but can't figure out where it's supposed to be. Does anyone have a photo with the location of the hole location, and why the assembly looks like installed. Thanks for the help I looked in the shop manual and it wasn't very clear. And looking behind and under the dash I'm don't see where it would bolt up.
Andrew Sorry if this is wrong forum Posted via Mobile Device |
Re: Parking brake location
High Andrew, the assembly should have two studs at one end, those go through the fire wall, the other end slips on top of the lower dash and is held in place with a large threaded screw. I'll see if I have any pictures.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Here's the dash side. Posted via Mobile Device Posted via Mobile Device
Thanks lee h any chance you might have a pic of where the firewall bolts should be? That's my problem right now is that I can't figure out where the bolts go.
Thanks Posted via Mobile Device |
Awesome build thread lee. So far you have the best pic of the parking brake assembly. I knew it would be on the far left like every other one but must be missing some obvious holes.
Here's a picture of the two studs coming out of the firewall.
Well that's what I figured, for some reason on my truck I only have the top hole and no bottom hole for the 2nd bolt. At best it looks like there is a smaller bolt coming from the fuse panel, but it's not lined up with the top hole. Ill have to dig around how am I missing this bolt ugh.
Yea I'm stumped the is only a top bolt hole. I took a picture but it won't dl. I take another and get it up ASAP.
This is from inside cab
Don't know why I can't upload the firewall side pictures. Could I need a different type of parking brake
