07-06-2003, 08:01 AM | #1 |
Rear Axle U-Bolt Removal
I am just having too much fun trying to remove the U-Bolts on my rear axle. I have soaked and soaked and soaked and beat and beat and beat. At this point I plan to cut the bolts in half and try to get them out. Any tips?
Dave |
07-06-2003, 08:42 AM | #2 |
don't cut your fingers off!!! those bolts are real hard to remove because the locking nuts are tight i used a 4foot piece of pipe on my breaker bar to remove them and it was still pretty difficult your better off just cutting and replacing them
07-06-2003, 08:46 AM | #3 |
I have the nuts off. Using a 5 foot breaker bar did the trick. I cannot get the u bolts out of the trailing arms.
07-06-2003, 10:11 AM | #4 |
Got big-block?
To get them out of the trailing arms, I put the nuts barely back on the bolts and beat the crap out of them with a 5lb sledge. They came out ...I had new u-bolts and nuts to go back with anyway.
SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
07-06-2003, 10:55 AM | #5 |
I always have to heat the nuts up with a torch, even then they are hard to turn
To get the ubolts out try threading the nuts back on part way then wacking it out with a BFH Last edited by Gee_Emm; 07-06-2003 at 10:58 AM. |
07-06-2003, 11:31 AM | #6 |
Try putting the nuts partway back on and then set the weight of the truck on the nuts. You can let the floor jack down quick onto a block and it'll be like using a two thousand pound hammer.
Saskatoon, Saskatchewan Canada |
07-06-2003, 02:12 PM | #7 |
they are correct puts nutz back on and tap (pound away) always a good idea to heat nuts and bolts up with a torch when they get awnry!!
