Old 08-27-2013, 10:57 PM   #1
Custom 68
Custom 68's Avatar
tie rod end heeeeeelp please
Ok all I'm on my phone so my searching will be easier tomorrow but I need help. I have my 68 that I converted to 73 to 87 spindles. I had all thus together and am now redoing the suspension cute to some problems so I know it's possible... I have the adapter from CPP to use the larger outer to the smaller inner. The outer I have is right but three inner had right hand threads and I need left. I had some on there but don't find them listed. I currently have moog es370r I can't find a "L".
Hope this makes sense. I know it's possible.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-27-2013, 11:20 PM   #2
Custom 68
Custom 68's Avatar
Re: tie rod end heeeeeelp please
Ok I was able to search shoulda done it before but it's rough on my phone lol. Looks like I need outers on the 68 ran in the inside. I will go by parts store and confirm. thanks guys. I will update.
Dave
Old 08-28-2013, 07:20 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You are correct.
63-70 0uters installed in the "inner" location.
Tie rod adapter.
73-87 outer tie rods.
They don't tell you this when you buy the "conversion" tie rod adapter sleeve.
I have that info in my disc brake thread.
http://67-72chevytrucks.com/vboard/s...68&postcount=4
3) If you must use the 67-70 steering components, you will need to change the tie rods:
* The 67-70 inner and outer tie rods are a smaller diameter (5/8") vs. the 73-87 tie rods larger diameter (11/16").
* The 67-70 tie rods are also the opposite thread direction of the 73-87 tie rods.
* 67-70 inner is RH thread vs. 73-87 inner which is LH thread.
* 67-70 outer is LH thread vs. 73-87 outer which is RH thread.
3.1) So to connect the 73-87 spindle to the 67-70 steering centerlink you must use a:
* 67-70 outer tie rod (LH thread) in the inner location.
* connect that to a tie rod "conversion sleeve".
(these are sold by many aftermarket suspension companies).
* use a 73-87 outer (RH thread) to connect to your 73-87 spindle.
* Again,... it's much simpler to use all of the 73-87 steering components.
Keith
Convert to disc brakes.
