![]() Join Date: Jul 2013
1970 cst dark blue exterior
Hello everyone, I am thinking of painting my 1970 cst swb white dark blue white 2 tone with a sandlewood interior. Does anyone own a cst with this color scheme. If so please post some pictures of the truck and its spid label.. It would greatly be appreciated. thanks
Re: 1970 cst dark blue exterior
The code 592 special two-tone looks really good on these trucks.
It consists of code 508 Dark Blue Poly (Ditzler 2169) body color and 521 White (Ditzler 2185) roof and below the rockers. It included the cab paint divider trim, however it also required the BX2 lower bodyside molding, but that was part of the CST trim. Member Davepl has a very nice 70 Sierra Grande he is restoring with that paint code. Here are an original period and a just before restoration pictures. You keep asking for SPID label information, what exactly are you wanting for information?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
What I mean by spid label is the glove box label with the paint rpo numbers for this color combination.
Doing a color change?
592 is the "Special Two-Tone" color code for a 508/521/508 truck. It is the darkest blue offered in that combination in 1970. The code itself is consistant, but the descriptions change somewhat between assembly plants and years. Common variations are WHITE & DK BLUE & WHITE or WHITE/DK BLUE/WHITE
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-28-2013 at 05:50 PM. |
Thanks ss tim that is what I was looking for. Can you post a picture of your glove boX label for me. How was the description written out on your 70 label was it wht & dk blue & wht. thanks
#6 | |
ok I am now getting the point it varies. thanks ss tim for your knowledge of the most common way it would be written out and the correct rpo numbers.
Here is a clip from the GMC above. It shows the correct format for an early 1970 (probably late 69) built "Z" Fremont CA truck. Both "S" St. Louis and "B" Baltimore are different as examples.
More importantly, Welcome to the Board!
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-28-2013 at 06:15 PM. |
Here is Davepl's build thread with post paint pictures. It shows the dark blue poly to good effect.
http://67-72chevytrucks.com/vboard/s...70#post6243170
